Disappointed in aftermarket front bumper choices.
The Adaptive Cruise only works with an aftermarket bumper if you relocate your sensor. And just be aware, Ford will not warranty and Ford Dealers will not "adjust" the sensor so it works correctly after you relocate it. There are too many liability issues with ACC for them to mess with it, so you are pretty much on your own if the relocation does not work.
On my Raptor, I bought the relocation bracket and it worked most of the time, but sometimes it would report an obstruction and disable itself until I shut the truck off. I adjusted it several times, but could not get it to work consistently. After all of the issues I had on my Raptor, I ordered my Tremor without ACC because I was planning to swap the bumper ASAP.
As you probably know, the sensor sits behind plastic on the factory bumper, but I am not aware of anyone who makes an ACC sensor location in the same place on their aftermarket bumper with a plastic cover. Even if they did, I know Ford would not warranty it or allow their dealers to work on it.
The ADD Stealth Fighter has a very short profile and does not interfere with my Tremor's camera as that was one of my main criteria when choosing it. They make versions with and without a winch option, but it is possible the winch version will interfere.
ADD Stealth Fighter no Winch
Ford may not warranty this but a dealer could always program and aim properly for customer pay $. Just part of a good build.
I asked my local dealer and they would not touch it. They said if my truck smashes into the back of another vehicle due to ACC misalignment, they would be liable for my accident.
Your dealer might feel differently, but it seems unlikely due to legal reasons.
Finally finished and installed!
SVC Baja Bumper
KC HiLiTES Pro 6 linkables (Nick@ApolloOptics)
Custom skid pan (PowerStrokeMagic)
ACC Relocation Bracket (DV8)
View attachment 39333View attachment 39335
Man, that turned out awesome! Glad we could get you setup with the Pro6 lights for it!
Are you aware of/carry a replacement bumper that works with the 22’s adaptive cruse as well as allows full camera coverage & does not have a winch?
Are you comfortable relocating your Adaptive Cruise sensor or do you want to leave it in the factory spot?
The ADD Stealth Fighter and ADD Bomber have an ACC bracket that can be relocated behind the grille and are both low profile.
Stealth Fighter:
Bomber:
Now, I did run across this bumper the other day. Steelcraft Elevation (and we carry it), keeps the the ACC in factory location with cover by utilizing the spot of the driver's side tow hook and it has a cut out for the camera, but you will lose some camera visibility.
Ranch Hand Midnight keeps ACC in factory location, but does not keep the cover. Although you may be able to modify the cover and rig it on there to cover it up. There is a camera hole cut out, but as you can see, you'll lose some visibility. This bumper is available with no front guard, but the bumper does stick out a good 3-4" and will block the camera at least to a certain extent.
In my experience, it varies from dealer to dealer. Most of the time a recalibration isn't needed, but we've had customers have the dealership recalibrate their vehicle, they just had to pay out of pocket. There is also a relearn procedure that you can run through Forscan.
I was able to reposition my sensor behind the grille with the DV8 bracket and rarely have an issue with it falsely reporting, maybe a couple times a year at most.
Probably already been discussed but do the ranchhand bumpers work with a factory winch, I'm guessing not?
Stealth Fighter:
Bomber:
Thanks for the detail on other dealers. It sounds like it is best to check to find out if they will do the recalibration.
If the bumper will accommodate a winch, then odds are it will fit. But that's not something we can guarantee. The WARN winch in that FP winch kit is made specifically for the SuperDuty from Ford and I do not have the schematics on it.
Definitely chat around, not all dealerships are created equal. Try to find a family dealer if you can, less corporate rules, if you will.
The factory winch is more compact than standard winches, so it should physically fit in any aftermarket winch bumper; however, it will not mount without modification.
The factory winch has non-standard 8" mounting holes and 8" fairlead. Standard is 10" mounting holes and 10" fairlead, which is what all aftermarket winch bumpers that I'm aware of are designed to accept.
This is exactly what I was concerned about. Thank you for sharing that!
Thank you for information I'll see what I can come up with.
