I received a Badlands 3-Ton off-road floor jack as a gift over a year ago. It sat in the box ever since, as I didn't have a way to safely and securely haul it in the bed of the truck. I had gone back and forth on mounting it to molle panels on the side of the bed, but I don't like the idea of that much weight suspended on those panels. I was looking for another solution, and I found it in the Demonized Fabrication mount.
If you don't mind giving up some bed space when it's mounted, then this is one of the most secure options out there. He offers a separate plate specific to our trucks that uses the bed bolts to securely mount it to the bed floor, then the jack mount mates to that. I might move it to the back corner to get it more out of the way, but I thought I'd try it near the tailgate first in order to make for easier access.
The jack handles lie in the base of the mount, and the jack itself is captured by the front axle as it slides into place. You then use the metal locking strap to keep it secure and locked away from those quick-handed opportunists.
It's not a cheap option as it costs more than the jack itself, but I take comfort in knowing I always have it back there, readily available and secure when rolling down the road.
