- OP 🔹
- #21
I just topped off the Def tank and got 11000 range lol
Nothing wrong with a couple of big jugs in your truck!I don't live near, or regularly pass by fuel stations that have DEF at the pump, so jugs it is.
You probably need to buy yourself a nice heavy boat or travel trailer. That'll solve the slow DEF usage issue!Seeing how it takes about 9 months to run thru a tank of Def, is it better to run to empty or top off with fresh Def? So the older Def can be diluted with fresh Def?
I have a 12k toy-hauler but it still doesn't use Def very much even towing.You probably need to buy yourself a nice heavy boat or travel trailer. That'll solve the slow DEF usage issue!
Interesting. Mine goes through a gallon every few hundred miles, depending on how heavy I am towing. Generally, my gross combined weight when delivering a typical tractor package is around 18-20k.I have a 12k toy-hauler but it still doesn't use Def very much even towing.
Do you ever tow?I just topped off the Def tank and got 11000 range lolView attachment 115220
