- OP 🔹
- #21
Got the storefront up and running, available for purchase now. See update in first post for details!
They are, just out of stock at moment as they are hand made and waiting on some materials to get delivered and will restock store in next couple weeks.Are these still available?
Awesome. Just happened upon this thread as I was looking at how I could add a 12v plug to my 2021 f350’s bed. I’ll try to monitor this as I am definitely interested.They are, just out of stock at moment as they are hand made and waiting on some materials to get delivered and will restock store in next couple weeks.
These would definitely interfere with intended install method as the Molle Panel covers a significant amount of area around the Boxlink mounting points. It's designed to set right inside that indent/pocket that surrounds the Cleat. You could certainly come up with some sort of riser to mount it on top of the Molle Panel but you'd be on your own to figure that out as I don't have them and don't have ability to test and make better recommendations.I may be interested. How does it work and play with the Built Right Mille panels?
The current version is working pretty well, and while it would be nice to go a bit larger, don't have anything in immediate pipeline. It's mostly just a size and right inverter for the location issue. This is something I'm still considering and keeping my eye out for other inverters that would fit the area well enough to not be too bulky and that also have desired plugs, and in areas that make sense to design enclosure around. I've seen a couple 'maybe's for slightly larger options, but nothing that I'm sold on yet, where I'm at the point of mocking up alternate versions of the enclosure.Have you played around with any bigger inverters or are you comfortable with the current size and staying there?
I might still be interested especially if you're willing to handle the install for a local brethren?Sorry, was out of town for couple weeks so been a little disconnected and wanted to get a few things stocked up before I started adding stock. Have limited stock available now in Blue Lettering option, and will continue restocking over next couple weeks as time allows.
To address a couple of the questions...
DM me with where you're located and what you're needing help with exactly.I might still be interested especially if you're willing to handle the install for a local brethren?
Hey thereUpdate 11/13/2024:
Ok, got a Square storefront up and running to accept orders and payments.
The listing on storefront represents that final/updated design and package contents that'll be included in purchase.
You may note that the updated design(pictures updated below), does away with the exposed mounting screws on backplate that was initially visible above and below mounting box. The updated design allows for a smaller footprint, and more importantly, much better isolation from weather/rain/etc.
Final price is between $335-$340 out-the-door and that includes tax and shipping. ($5 option for colored text on doors, multiple color options)
I'm going to initially 'limit' stock on first batch, so depending on how quickly people jump on this, if first batch goes quick, be patient, and I'll add additional stock as I get orders fulfilled and get good gauge on how quickly I can get them out. Initially going to quote 3-4 weeks (worst case), but hopefully should be quite a bit quicker than that.
Purchase Here
The listing for the inverter is available on the product details page for you to purchase directly from Amazon.
Love my Super Duty, but one of the things that's really annoyed me for a while was the lack of power outlets in the bed, coupled with the lack luster stock interior inverter.
I've been looking at other solutions for a while and seen various DIY inverter swaps for the interior, and various other ideas but nothing I felt was a good attempt to mimic the more built-in / minimalist look of the Pro Power, but that can be retrofitted onto any recent Ford Truck with minimal impact on bed space. I also decided not to replace or modify the stock inverter setup and wanted to leave that in-place, with anything I added being a separate system.
So, I went about first identifying a few different Pure Sine Wave Inverters that were a decent upgrade from the OEM interior inverter, but also were not so massive that they became difficult to mount somewhere easily. I settled on a 750watt, 1500 watt peak option, that ran my portable compressor with no issues (something stock inverter can't). Has two standard 110 plugs, multiple USB ports A and C, and a 12V Cigarette plug.
Looking for where to mount it and how, I decided to use one the Boxlink anchor points at the rear of the bed. These sit in a nice, recessed pocket and figured I could reuse the existing screw holes where them mount, and not have to drill any additional holes in the bed. Next, I didn't want to just slap it up there exposed to elements, so I spent a while designing and fabricating a customer weatherproof enclosure that houses the inverter. This took quite a few prototypes to get dialed in but think it came out pretty awesome, with a pretty darn close to stock look. I suspected others might be interested in a similar setup, and while I installed this on my 2022 F250, this should be adaptable, to F150s as well back to 2015 at least that I can tell. I've looked at several trucks, even newer 23 F150 and looks like the Boxlink 'pocket' size and mounting holes are identical between all the various Ford trucks. This mounting location requires drilling one, approx. 1.25" whole for the power cables in the bed.
Posting some pictures of the install and my initial prototype version mounted up. The final version is essentially the same but looks slightly different as I was able to further reduce the footprint and improve weatherproofing. Since there's not really anything like this on market that I could find, I wanted to put this out to community to gauge any interest in whether others would be interested in a 'kit' option that included mounting box, 50ft of inverter cable(cut and terminated), fuse, and mounting hardware. Could then provide direct link to the compatible inverter on Amazon and let others purchase directly themselves, rather than being middleman on that.
Posting up some pictures and videos for reference. Haven't decided on exact price yet, but thinking about $300 for the full kit? There's quite a bit of time to print each box and prep them... Based on my research and some other 'solutions' I've found I felt that was pretty reasonable with very large and bulky alternates that just slap an inverter into a swing box, costing more than double that price.
If you'd be interested, or have any feedback let me know, if so I can setup a Shopify page to take some orders. It would likely be a 4-week lead time to get them out, and probably limited number of orders initially depending on interest level.
Video:
Yes, that's exactly the goal of this setup.Hey there
Will this setup enable me to have a 110 outlet?
Yeah I guess dumb questionYes, that's exactly the goal of this setup.
Yeah, Molle panel would definitely interfere with it so unless you want to do some additional modifications on your own, would have to come off. Install isn't terribly hard or complicated though. Mostly just routing and securing cables along frame from front to back of car.Yeah I guess dumb question
But I have a molle panel there so I’m assuming I’d have to remove that
Also I’m not really that good at these type of installs so I’m guessing I’d have to take it to a shop for install ? Or is it not that hard to do?
