Clearance lights
I have the same ones. It looks so great with the black package. Nice choice. The only thing is, there was some discussion on another thread that somehow those interrupt the tire pressure monitoring system and cause it to go out temporarily. It seems to me that, that is the case. When I turn my lights on at night about 30 minutes into the drive my TPMS goes out.
I have not heard of this....I will be more aware, thanks.
Do you have these drilled already? Or are you asking for suggestions and this is just a mock up?
Personally, I think fords factory placement looks the best. I took some closer pictures so you could see where they are at from the factory. Don’t mind the garage mess. That’s for another day when it’s not 110 degrees.
Looks like you have the middle 3 in the same position. The 2 outer lights from ford are in the “recessed rib” area towards the outside. Not saying there is a right or wrong here, just trying to give you a reference if you want to try some other arrangements.
These are the wireless one that has a base attached with 3M double back tape. Not installed yet, just sitting there for the picture
These light have a larger footprint than factory lights. I got them moved outboard another inch , but they won't fit in the outer groove.
Do they look too much in your face if you slide each of them towards the windshield a few inches so they clear?
I installed the Cab over America lights on my F350 with the moonroof and I really wish that I had the stock hard-wired ones. Because of the moonroof, they are on the part of the roof right behind the windshield, where it is very curved. As a result they don't conform to the roof line of the truck very well. I even adjusted the plastic covers and the batteries, which helped a little. So if you don't have the moonroof, go for it. But if you have a moonroof, take this into consideration.
FWIW the factory lights don’t sit flush on trucks with the moon roof either. Might be more prominent with the Cab Over America ones, but not a solved problem with the factory ones.
I did not have them on my 2017, so I don’t have a point of reference, but should the base of the lights not sit flush with the roof…
View attachment 51691View attachment 51692
Yes, the roof slopes down toward the windshield and they look best level.
