Chassis Unlimited Octane Rear Bumper Review
Black Friday 2022 I ordered a dual swing-out arm Octane Rear Bumper from Chassis Unlimited. Initially, I was quoted a delivery shortly after Christmas, but that never materialized. Whenever I reached out, it was almost ready. Then this, then that until it finally shipped on February 22nd.
The pallet arrived at a friend’s business as he has a loading dock/forklift. I went the next day to take look, but felt quite disappointed. The pallet was wrapped in heavy-duty shrink-wrap which was fine. The bumper was “protected” by Smirnoff Ice cardboard boxes and maybe that explains the issues. There was no mounting hardware, no brackets. Just the bumper and the spare tire mount.
I reached out to Chassis Unlimited the same day, but it took additional 2 days before a shipment went out. It looks like two shipments actually, which caused additional confusion. One box came via UPS and one via USPS.
Installation: Ok, time to get this thing installed. If you can hold/operate a drill or impact driver, you can install this thing yourself. The instructions were not provided with any of the shipments, but fortunately I had reached out about it when I requested the mounting hardware. The instructions were extremely generic and it seems to be one set of instructions for all their bumpers. YouTube to the rescue, but there is no install video for this Chassis Unlimited bumper (or for any other one with the right level of detail). Fortunately, I found a video from Chandler Truck Accessories (CTA) for one of their rear bumpers. This video got me 80% to the finish line. Removing the old bumper was easy following the Chandler Truck Accessories video.
Then the problems started happening. Nothing to be a showstopper, but annoying and time consuming and I have additional work lined up as well for reasons I will explain shortly.
Mounting Brackets. I had to guess how they went onto the truck, but figured it out quickly. The CTA video helped. Then I transferred the parking sensors to the new bumper and things turned bad. The cut-out holes are a tiny little bit to small. Just enough that the sensors did not fit back in the holding. I tried all 4 sensors and then called Chassis Unlimited. I was eventually told, that I have to shave down the sensors or the holdings to make it work. This was bad, but I made it work. However, there is a weld on the left side of the bumper near where the sensor is located and the sensor wire connector hits the weld just right to prohibit installation. So, I shaved down the casing of the wire connector for the harness as well. Two of my sensors are now loose and I will need to glue them in, but that is for another day.
License Plate lighting. The instructions barely talk about the LED lighting for the license plate. It feels like some obscure LED lighting. It works, but you have to mount it before you install the bumper and then I wonder how I would ever get the license plate off or install a new rear camera with a license plate bracket?! The provided LED lights feel cheap and the wiring is even worse. And – there are no instructions of how to wire it to the existing harness. Again, the CTA video provided a solution. I will probably work out something different for this, but for now it works.
Rear lights. The bumper has two openings for 3” LED Cube pods/lights. I did buy two Diode Dynamics Stage Series 3" SAE/DOT White Sport LED Pods. There is no way to flush mount these. Even leaving a tiny gap is difficult. I have yet to wire them up, but I have the feeling they are pointing a bit upwards. It’s not horrible, but it is definitely not good or great. I am considering to buy other LED pods that may fit from the outside and drill some holes into the bumper to have them flush with the bumper. I will decide when I have them wired up, but right now I am not sure I like this.
Mounting the rear bumper. My buddy helped me to mount the bumper and we ran into a major issue on my 2022 F250 Tremor. On each side at the tail end of the truck where the original bumper fit like a glove there is some plastic cover mounted. Again, the instructions don’t mention this, but to make the bumper fit so that you can bolt it on you have to remove the plastic pieces. It is a total of 4 fastener clips/fender clips or whatever you want to call them. Once these plastic covers are removed, the bumper fit onto the mounting brackets and I was able to bolt it on. There are now openings in the fender that I need to seal up or cover up. Most people will not notice, but I think it looks like sh!t/sloppy/cheap.
Home stretch. The opening for the trailer hitch plug is too small. It is too low as well. There is no way the standard plug from Ford is going to fit in there. I started shaving off the bottom of the plug, but realized once I had enough height clearance, that the plug was also too wide. I am not even mentioning that the flip cover is hitting the bumper and will not close ever unless I come up with something. But wait – there is more. Not sure if to blame Ford or Chassis Unlimited, but the plug/bumper is now further away from the vehicle body and the wiring harness will not reach the plug – ever. The only solution I see is to cut the wire and make my own extension to get it connected. So, I am debating how to fix this. I do not have a metal grinder, but if I can wide the hole for the plug I may get the plug into the bumper. Not sure what to do about the fold-up lid/cover. It looks like the specific plug section may still be covered if I shave off a bit more. I am not planning to tow anything, but that does not mean this needs to be done properly.
My opinion: So, I am quite disappointed at this point. Parking sensors are pretty much the same – no matter the car/truck manufacturer. Why I am forced to shave down the plastic of my sensors is beyond me. I get that the bumper is thicker, but that cannot be it. This is sloppy engineering in my opinion. If I search on YouTube, other bumper makers get this done just fine. But that the trailer/hitch plug does not fit – I mean – not even close – that is really bad!!!! Really bad. The opening is too low and needs to be moved up a quarter or a half inch. And then it is a tiny bit too narrow. Just enough to make this a super frustrating experience. It took me ~4 hours to install the bumper. Probably could have done it in less than 3 hours. I assume I will need another 2 hours to address the issues mentioned.
Ok, but what about the bumper itself? The right-side swing-out arm had some minor scratches on the powder coating, but those will be invisible once the spare tire is mounted. Speaking off – I had to look at product pictures on the Chassis Unlimited website to find the right way of mounting the spare tire mount. Anyway, everything feels solid. It is a good bumper. The welds look good, the powder coating looks good. The swing-out arms work and feel solid. The truck looks great and probably even more, once I have the spare mounted. Had to realize that I could not use locking lug nuts with my Method 305 HD wheels and had to order other lug nuts. The bumper will grow on me, I love the truck's look, but I had higher expectations.
PS: I wish they would have shipped some of that Smirnoff stuff with the bumper. Needed a drink this evening.
Fantastic write-up, and thanks for sharing! That really is disappointing.
Did you ever reach out to Chassis Unlimited about the trailer plug and reverse sensors fit? See if they had any thoughts or suggestions or plans?
Obviously wouldn’t alleviate the miss in design and/or manufacturing in the first place, but good customer service after the fact can help a lot - though sounds like that’s lacking already based on your other interactions with them.
I would write to them an e-mail with this write up. Provide this link.
Perhaps this could serve as a wake up call.
This write up is now available to the world and could impact their sales and reputation significantly.
I reached out when I did not get the sensors inserted. All I was told to shave off some of the plastic, but no specifics were mentioned. By the 4th sensor I had it down. There two "clips" that need to expand to accept the sensor. As there is not enough room in the opening they cannot pull back and accept the sensor. In hindsight I probably should have used an angle grinder and widen the opening, but I would also need to seal it to prevent rust.
I did not reach out about the plug. If you look at the images, you can tell that the opening is too low and there is not enough room to shave of metal at the bottom. I do not have an angle grinder, but have one on order for tomorrow or so. I shaved off some plastic of the plug already and I hope I can widen the opening enough with the angle grinder. I hope that is enough and then I need to think about how to seal the plug. I am not planning to tow anything, but it is important to me to maintain full functionality.
I emailed them today - very polite, constructive feedback in my opinion. I did not provide a link back to this discussion.
  • Like
Reactions: ccw
I'll be eager to know what they reply.
An apology would be minimal; 50% off for a front bumper with all needed hardware, components, and free installation would be a treat.
Noticed you're in California; depending where abouts, they may not be too far from you to walk in and have them fix their mess.
I think they are in Tracy, I am down just north of San Diego. 7 hour drive if I am not mistaken. I hope my email helps the next customer to have a better experience. I have some tools and stuff on order and will finish this up on the weekend.
On second thought, I hope I am still a few customers out til where they really get it worked out :LOL:
  • Haha
Reactions: ccw
I installed their bumpers last weekend and didn’t have any issues. 100% happy with them.
I installed their bumpers last weekend and didn’t have any issues. 100% happy with them. View attachment 114861View attachment 114862
Well on a happier note; I'm glad to read this comment after all.
I was also wondering; did you stick with the stock/termor Warn winch? If so, how was that experience/mounting?
I also noticed the rear bumper still has not license plate lighting?
Maybe @Chris-DTA's was a lemon.
Your trailer wiring plug looks higher than the OP’s version. Wonder what went wrong with their process in his bumper’s design? They had to know the plug should be in the same location across all bumper styles.
Gotcha. All of that makes sense. If it were me I would be pushing on them to fix the trailer wiring hole somehow; taking an angle grinder to a brand new, and expensive, bumper is unacceptable. With an understanding that things sometimes go wrong in manufacturing, of course.
Regardless, I hope your other email to them hits home and they take some steps to improve things.
No I sold my factory winch and bought a zeon 12s to put in the bumper. I relocated the control box under the hood.
The license plate lights are the bolts. They work great. The wires are small but not really a big deal for me. I made a new harness using a curt 7 way extension that powers the reverse lights (rigid flood) and the license plate lights.
You do have to shave a tiny bit off the locking tabs on the reverse sensor holders. Also not a big deal to me and they all fit nicely.
Looks very nice :) What winch are you running?
Zeon 12s. I would be pissed about the trailer plug and I’m curious what they say about it. They really should send you a new center section with the opening in the right place and the spare tire lock hole.
I was bummed about shaving the sensor holder things but can always buy new if I take the bumper off. It talked about it on the instruction sheet but of course I didn’t read that until afterwards.
For your trailer wiring I’d recommend getting a curt or other brand 7 way extension. It will extend your trailer plug and provide all the connections you need for the rear lights.
If you need to install a camera over the liscense plate lights you can just make a small slit in the mounting brackets and slip it over the wires then bolt it on.
I didn’t have to remove the black plastic things on the bed but I did have to trim the bottom of the bracket for the tailgate assist thing for the bumper to sit higher.
Thanks, man. I did not know such a thing (7 way extension) existed. That will save me a lot of trouble and work. :) I'll try that with the backup camera as well.
More issues - unfortunately. After mounting the spare tire to the right swing-arm everything looked Ok, but after driving the truck today for the first time I noticed that the bumper is significantly sagging on the right side, a little less on the left. All bolts/nuts were tightened and double-checked multiple times during the installation and before we lifted the bumper onto the truck and secured it. The bumper is connected to the brackets with 3 bolts and everything looks flush and tight.
However, I did not realize this at first, but now it potentially makes sense. Both brackets have an additional mounting hole for a nut/bolt, but only the left side of the truck has a matching "partner" in the frame. There is nothing on the right side where the bracket has an opening. Granted, the brackets have additional holes and no match on the frame I did not think much of it, but now seeing this it may very well be the reason.
I just reached out to Chassis Unlimited and sent them pictures for review and asked for a phone/discussion in how we can resolve this issue.
  • Sad
Reactions: ccw
More issues. I emailed Chassis Unlimited and will call them in the morning. I did email them twice now with no/zero response. Hopefully calling them will solve this situation once and for all.
The bumper looks great, but that is about it.
  • Sad
Reactions: ccw
At this point, it might be worth a drive up to Tracy and let them see the mess they created.
A personal presence might result in a rewarding situation.
Yeah I would like to hear their explanation for the issues. Hopefully they’d swap his bumper for one with the right trailer plug hole.
This whole thing is so disappointing. Nothing worse than spending money on some and having it suck. Are the mounts moving with the weight of the tire on there? I assume you are going to drill out the extra holes and put bolts everywhere you can hopefully that will fix it but still annoying when they are supposed to be ready to go.
I called and left them a voicemail when I was doing mine and they called me back pretty quickly.
I think you are spot on with the mounts moving or shifting with the extra weight on the bumper. I am concerned about drilling holes into the frame and potentially weakening the frame in that area. The left side has a hole that is not on the right side of the frame. I am probably OK with drilling a hole in the same location on the right hand side. But I am also concerned about how much weight can I actually put on the bumper. I have not installed/mounted anything to the left swing arm yet.
Stuck in meeting for another 35 minutes and then I will call them up. I am considering driving up there, but it depends on what they say on the phone.
