Chassis Unlimited Group Buy Interest?
Current questions I have pending with CU:
1) Plate light cutouts like OEM - is that possible as an option?
2) Will the Carli Trophy Hitch work with the Attitude Series rear bumper ('22).
I will let you all know as soon as I hear back.
For #2 I was informed that these bumpers are designed for OEM spec hitches. So if Carli uses OEM spec (spacing) it will work. I do not have this hitch, otherwise I could compare personally.
Just confirmed, chassis unlimited WILL cut out plate light holes for us. These are the lights I had shared with them - the ones I plan to use.
Great lights, tremendous output, can almost serve as a supplemental reverse "area" light but for whatever it's worth, one of mine just went out.
Not sure if MM has lifetime warranty on these but I need to get under there and check the wiring.
I have been through some really nasty stuff in the last month; my truck is a total mess right now. She needs some love.
By the way, you have worked out a great deal on this bumper, plus you will get bonus cuts for lights -- CU is treating you well. I am thrilled to see that, will be more thrilled once the bumper is in place.
They seem to be doing great! I am going to have them put a hole in for my ARB air chuck too. Then I will be bringing it to the powder man! :)
You think they’d be open to cutting the BD flush mount light holes vs the ones they already cut?
And would those plate light holes fit the OEM lights in them as well?
I bet they would fit OEM - I need to check. If the Morimoto are a direct fit replacement, they should.
I will check on the BD cutouts.
Interested if they will include the license plate stock lighting cutouts. I would need both the rear parking sensors and OEM license plate lighting cutouts.
10-4! I will add your name to the roster! :)
I am thrilled to learn that CU is accomadating customer's request(s) -- that speaks volumes.
I didn't exactly pull the Mori's plate lights out to test fit but pictured below is the OEM compared to the installed Morimoto plate light. They appear to be same and their website has them listed as direct fit. Seems to overlap perfectly to MM's replacement.
Evetually I will need to pull one of them to check/replace, due to one being out, but that's not going to happen anytime soon.
This time of the year, we're just too busy.
When will this group buy be happening?
Trying to get this pulled together for Feb/March timeframe. There are some other ones in the process too - but that would be best.
For anyone upgrading their license plate lights with Morimoto LEDs, here’s a heads-up about this setup.
One of my plate lights stopped working a few weeks ago (more like months), and when I finally got around to checking it out, I wasn’t surprised to find the light itself wasn’t the issue—LEDs usually last longer than incandescent bulbs.
The real culprit is that the factory socket plug, where a bulb would normally go, is used as a connector plug for the LED pigtail end. The factory harness includes both the pigtail and the bulb socket, and once the light is recessed into its cutout, this connection is left out exposed to the elements. On top of that, the back of the light assembly is left open by Morimoto as if a bulb would to be inserted in here. Morimoto stuck with this factory-style design despite not using a bulb (not sure why), which leaves the LED board exposed to moisture and debris over time—a perfect spot for corrosion to form. Yet, despite all this, it still wasn’t the issue.
Picture taken from a video but you can see the LED pigtail end is just corroded from moisture and elements.
LED board, how it looks after it was cleaned to the best of my ability.
How it should look:
The problem turned out to be corrosion on the plug from exposure to the elements. A quick cleaning and brushing, followed by some dielectric grease, got the LED working again. I then repeated the process on the functioning light, knowing what could happen over time, but accidentally pulled the soldered terminal from the board (didn't even realize when this happened as I was cleaning but it did). Now I’m stuck deciding between attempting to solder it back, which would be tricky due to the tiny hole at the back of the light assembly, or just ordering a new one.
Cleaned and ready to be recessed into its cutout hole. The light’s locking tabs were removed for my installation, so it simply sits recessed into the hole. You could use some glue to keep it from falling out, but in my case, the glue was so dry it didn’t matter, and with all the grime, it stayed pretty secure for over 2 years.
I’ve got some updates on this whole mess and will try to share them tonight. :mad:
Any luck/update on this one? I am pretty bummed about the open to the elements thing. I wonder if using RTV would seal it right up.
I apologize for the delay in providing an update; I’ve been tied up with other life matters that have taken most of my time -- or whatever is left of it lately. Over the holidays, I had the opportunity to investigate this issue further, which only increased my frustration with the shop responsible for my build. While I understand that achieving perfection in a build requires time and precision, such a standard should be the primary objective for those who perform this work professionally (and for a living). Now that that is off my chest, I was surprised no one caught what I eventually noticed—or if they did, no one ever told me. After my initial posts, I realized Morimoto left the light assembly open so the pigtail could be tucked inside, which solves problem number one. This effectively resolved the first problem, and while it may not be immediately obvious, it raises the question of why such a step would be omitted by a professional technician.
The second issue became apparent upon further inspection. Comparing the current setup to the stock bumper design by Ford, it is clear that the license plate lights were installed in a different and less effective manner. The current orientation fails to direct light toward the license plate, instead projecting it outside the bumper entirely. Although I am still exploring potential remedies, from a legal standpoint, the presence of any light technically meets the requirement. Nevertheless, my dissatisfaction with the situation led me to temporarily purchase LED bulbs from a local auto parts store as a temporary solution.
Clearly, they have been rotated by comparing the pictures above.
...and now, to a glass of Bourbon to ease this frustration...
Sucks to hear and hope you get to a remedy soon. Here in Washington, we have to both light up the plate and be careful that it is not too much light and shining in any direction but towards the plate. I got pulled over in my old Jeep because the aftermarket light (hooded LED line the pointed down from the top of the plate) shined too much light down and back....
On that note, I shall join you in some sympathy bourbon 🥃☕️
Hey folks,
We are looking to make this a group buy in March. I would love to get some higher numbers, so if any members are looking to hop into it, please let me know. I will be asking for a deeper discount based on numbers - but we have to have that demand.
Thank you for all of those who have showed interest, or have also supplied tech specs. I cannot wait to take my rusty OEM bumper off the rear of my truck. I am beyond disappointed that the plastic wore through the paint.
I might be in for this for the Attitude front and rear. I have been so focused on getting my GX finished that I haven't done much to the Tremor in the last bit.
Keep us posted.
