Carli E-venture not sitting level
The pucks are adjustable - you just pull out the shims to get the correct height. I had to adjust when I installed the full progressive vs the HDX that was in the truck before. I guess the scenario you outlined above could be an issue still, but if I'm going to be loading up at all and not utilizing full travel I would just slide the pucks in.
That’s pucking cool
My truck has the standard Carli full progressive leaf springs. I run with a toolbox in the bed full-time (~200 lbs.). I also have the 60-gallon fuel tank and an MTI subwoofer enclosure under the rear seat. I have no shims on my full travel air bag kit, and the bags still rest on top of the bases. I keep an air jack in the bed, and I use the on-board air to lift from the hitch to insert the pucks when needed. This leads me to believe the HD springs are the solution for me.
I run the stock rears for the time being. With my full travel bags one slides out no problem. The other is tight so I just drive onto a 4x4 and the rear articulates enough to get the puck out.
very good to know. Mine have no shims and gobs of clearance now after the spring changeout. It'd be nice to shim them to the best working height and unloaded clearance. Thanks for the info
I leave for the holidays and come back to chaos! A lot to digest in this thread.
It's completely normal to see deviation from truck to truck; as much as i wish these heights were exact sciences, that's far from the case. There are a lot of production and configuration variables that can affect a truck's stance; more-so with AUS trucks that are RHD. I doubt that has anything to do with front to rear height as you have here, but worth noting there's more than meets the eye at play.
Have you confirmed you only have 3-400lbs in the bed? It's not uncommon for estimates to be substantially off from actual weight - in fact, my tech dept. would tell you it's common. If you remove all weight, how's the stance?
If you want the truck up another 2" from where you're sitting currently, I would have no issues installing a 2" block. This will NOT change anything about the way the rear end travels. The rear travel is limited by the shock; adding a 2" block will not change the stroke of the shock as it's mounts weren't altered. It will still bottom out and top out in the same place. Putting 2" blocks on the leaf springs will change the spring - at full bump (bump stop hitting the axle), the leaf spring will be pushed 2" deeper into it's stroke of travel than it would be without the block installed. The concern here would be weather the full progressive leaf springs could take 2" more inversion at chassis bump without affecting the spring steel's longevity.
Our leaf springs are shot-peened and preset. They're fulling inverted on a CNC to preset their rate, so the additional 2" shouldn't be an issue.
if you're against blocks, you can install the 5.5" leaf springs as they're identical to the 3.5" aside from arch.
Thanks for you’re reply.
I completely understand that there a lot of variables that come into play with final heights.
Yes, so I’ve written out a detailed sheet of all the items and I’m right around those weight figures. What I’ve worked out is for every 400-500lbs on progressive leafs, the truck will sag 1”.
If I remove all the weight, the truck sits dead level.
Thanks for your advice on the 2” block. However I had to make the best choice with the information I had at the time. It’s quite frustrating because I got the advice that a 2” block would not work properly at all so I went and ordered the 4.5/5.5” leaf pack. At the end of the day I always want to do things correctly and have a solid setup so I understand it was probably the best choice, just darn expensive!
By the time all this is done I’m expecting the rear to now sit 1” higher than the front and then I can tweak the front height slightly with the adjustable coil spacers. I’m not engineer by any means but I would have thought there would be half n inch to an inch of adjustability with all of the front end components whilst still aiming for that 4-5 degrees castor?
2" block is not ideal, but the price trade-off would have me considering it. If you want it done right, a proper spring is the right way and your estimates should be pretty close with the weight you're running. Even if it's high, you can always add a bit more weight to get the rear end where you want it. Doing this, my preference would've been the HD springs and loading them to your desired stance but it sounds like your solution is already in process. The HD Spring's additional capacity stems from the higher gauge spring-steel; the 5.5" height is achieved via more arch. Longvetiy under load, the higher gauge steel wins. Ride quality will be softer with the 5.5" springs as they have a lower effective spring rate. Regardless, we're splitting hairs - you had 3 options to choose from, Block would be a band-aid, 5.5" and HD are the actual solution and which is best depends on your end goal but either should be good to go.
The front... The bump spacer we provide with the system accomodates the compressed height of the coil AND compressed dimension of the shock. Adding a spacer to our spring will increase the effective compressed dimension of the coil so it may bind before chassis bump - this will affect spring longevity. Additionally, caster will be harder to achieve and you may put yourself close to top-out on the shocks. 1/2" should be doable; going to 1-1.5", i think you're getting into the danger zone.
I wished I got your advice before in regard to the block but like you said I’ve probably made the best long term choice going a full leaf pack. Thanks for confirming, I’m keen to see the final height it sits but it should be very close to my calculations.
Thanks for also confirming the front end. I definitely won’t be using the coil adjusters more than 1” at the most, most likely slightly under that. I want the rear to sit about half n inch higher than the front and should be able to achieve this whilst being able to run the Long Travel Bags. I can’t wait to have the setup finalised, it’s taken some back and forth but I’m beginning to appreciate there are probably quite a few guys who go through multiple adjustments to finish up at a setup and stance that’s works for them.
