I've got the 1.5" block from PMF in my truck. Full e-venture setup. No issues.
I wish I could roll into a shop and do the same haha!I had the lighter springs in the rear after my install and instantly noticed the potential rake/sag problem. The next day, I was back at CJC and went with the HD pack, and don't regret it a bit. I don't carry much in the way of a load and just finished a 1500 mile trip this last weekend with my woman. She commented on how nice the truck runs, but that's with 37's on there, which to my reckoning will affect the unloaded ride more than anything. I also run full travel airbags, have the Kings, and the axle's travel is free the first 1.5" , and that's with the pucks installed.
Thanks mateYou’re correct I’ve added a 1”-1.5” block twice on 2 different trucks with full deavers and it didn’t affect anything other than ride height
Thanks for that, and I’m assuming that’s with full progressive springs?I've got the 1.5" block from PMF in my truck. Full e-venture setup. No issues.
The truck is normally empty and has a smartcap shell on it. Not sure that adds much at all. Traveling with nothing on the hitch, I was carrying circa 6-700# in the back for this last trip. Not much of a load by any stretch. Around town it has a couple of boards and wetsuits and that's it. I remember measuring the top of the wheel wells with the standard progressives and the rear was about 1/2" higher in the back when I brought it home from the install. I threw some weight in it & wasn't happy with it at all. Now it sits 1.5" plus higher. Top of the front wheel well is at 45". The rear is at 46 5/8". It looks like a normal badass truck to me. Not a squatter.How much weight do you have in your bed? And does this mean you’re now sitting level or rear end high?
Your truck is exactly the look I’m trying to achieve, with about that 1/2 to 1” higher rear end WHILST carrying a constant 400-500lbs (I added it all up more precisely and was more than originally estimated). I feel if the truck is dead level it still looks front end high to the eye.The truck is normally empty and has a smartcap shell on it. Not sure that adds much at all. Traveling with nothing on the hitch, I was carrying circa 6-700# in the back for this last trip. Not much of a load by any stretch. Around town it has a couple of boards and wetsuits and that's it. I remember measuring the top of the wheel wells with the standard progressives and the rear was about 1/2" higher in the back when I brought it home from the install. I threw some weight in it & wasn't happy with it at all. Now it sits 1.5" plus higher. Top of the front wheel well is at 45". The rear is at 46 5/8". It looks like a normal badass truck to me. Not a squatter.
If you're looking to keep it level with a minor load, this probably isn't what you're looking for. This will keep a little bit more of the original rake loaded with 500-600, and stay in that 1/2" zone with a 1000 to 1200.
I know somebody here said the HD springs road good but that is the first time I’ve ever heard that I remember asking Chris at cjc this exact question a couple years ago I was told unless you’re hauling heavy all the time or have a constant heavy load in the bed like close to 1000lbs they ride like a brickYour truck is exactly the look I’m trying to achieve, with about that 1/2 to 1” higher rear end WHILST carrying a constant 400-500lbs (I added it all up more precisely and was more than originally estimated). I feel if the truck is dead level it still looks front end high to the eye.
Now I’ve got a unique question! - what will ride better:
- a 5.5” full light progressive leaf riding an inch or two lower in its travel or
- a HD progressive leaf riding at the top of its travel
Yes, everything you can get lol.Thanks for that, and I’m assuming that’s with full progressive springs?
I had the HDX on the truck when I bought it - prior owner had a slide in camper. They were very stiff.I know somebody here said the HD springs road good but that is the first time I’ve ever heard that I remember asking Chris at cjc this exact question a couple years ago I was told unless you’re hauling heavy all the time or have a constant heavy load in the bed like close to 1000lbs they ride like a brick
This is exactly what I would have assumed, why call them a 1000lb spring if they are not targeted at that close to 1000lb weight range?I know somebody here said the HD springs road good but that is the first time I’ve ever heard that I remember asking Chris at cjc this exact question a couple years ago I was told unless you’re hauling heavy all the time or have a constant heavy load in the bed like close to 1000lbs they ride like a brick
I fully appreciate this, I’m reasonable with my expectations but on the other hand trying to use every best possible part on the market today to achieve the very best possible ride. I also understand everyone’s definitions are relative, but it all goes into the mix."good" is pretty subjective. I bought a one ton truck because I use it like a one ton truck. If I was using it as an off-road beast, I might have gone another way. I have a built CJ7 to scratch that itch. I saw Cody's truck in their shop before I ordered my original setup, and it's a beast. If I ran a heavy camper, it's a perfect setup. You give up load capacity going with the standard progressives, it sags more under a load, and it rides smoother unloaded. You can rely on airbags for compensation, but you just threw your ride out the window for that. That, and with standard progressives, it sits 'level', which is not my preferred look. When i picked up my truck at CJC after the retorque of the rear HD leafs, Cole, the other owner of CJC asked if they could take an extra half hour and shoot some pictures for their Instagram page.
I've ridden in my truck with 37's on a stock tremor suspension, then a full catalog Pintop with full travel airbags and standard progressive leafs, and then with the HD leaf pack. I still have the stock springs in case something didn't work out. I'm also not a big fan of blocks. With blocks, I think you're just giving up working travel for clearance or a look.
That's just me. I realize I'm in a minority when it comes to suspension discussions here, but I'm using my truck to haul, travel, tow, and as an occasional most-capable recovery vehicle, not a chase truck down in baja. My 3rd gen 3/4 Dodge was set up like that. It rode good, particularly after I went from Bilsteins, to Kings. For me, this is my best truck how I use it, and honestly, if it rode like a brick, my passenger seat would be squeaking like a MF. For me, it rides good.
As far as Aussie's last question, I'm unqualified to comment, but I'd be hesitant to put the 5.5 pack into the mix on my own dime.
Just do the full travel airbags.@sarj
How would you relate the ride with the HDX springs to the stock Tremor rear leafs? Noticeable difference?
Like you, I need my truck to do one ton truck things whenever it's time to do them. I probably ride around with a minimum of 250-350 pounds of stuff in the bed at all times and when I hitch up the trailer with tractor/implement it's somewhere around 15K-16K so I'm thinking HDX is probably right for me if I decide to start playing with the suspension. Using the Carli standard springs labelled as for a "light 3/4 ton" would leave me a little concerned with doing farm truck stuff.
When I had the softer progressives with the full travel airbags and the pucks installed with a full tank of fuel and an empty bed (no shell either), I had contact on one of my pucks. No load in the bed. In my research before purchase, someone here on the forum mentioned they ran into that situation too, and that they needed to lift the truck a little to get the pucks out. It made me wonder how you'd manage if you found yourself on the road with a partial load in the bed wanting to add weight in the bed or on the hitch, and you wanted to install the pucks. You're going to need to lift the truck. I like the free travel airbags, but not cutting it that close. That influenced my decision to move up to the HD's.Just do the full travel airbags.
I have the full progressive and they are great when I have 300-500lbs in the bed and when I'm towing heavy I just throw the puck in for the full travel bags, inflate and off we go.
They have "soft-ride" progressives, HD's, XHD's and XXHD's. I have no experience with the XHD (HDX), and the the XHD is calling out for a 1800-2000# constant load. I'd expect to need a kidney-belt if you ran those in an unloaded truck and was driving over anything but a smooth road. You'd have to have a real good reason to run the "X"'s. The effective range (800-1200) is more in the range where I use my truck, but you and I are using the same logic as far as application@sarj
Interesting direction. I'm sure everyone will appreciate your report.I will report back once this is all done!
Hopefully this helps others in their truck builds and a big thanks again to all those who helped.
Thanks for the detail. You are correct, I misspoke. The HD is what I have been considering not the X.They have "soft-ride" progressives, HD's, XHD's and XXHD's. I have no experience with the XHD (HDX), and the the XHD is calling out for a 1800-2000# constant load. I'd expect to need a kidney-belt if you ran those in an unloaded truck and was driving over anything but a smooth road. You'd have to have a real good reason to run the "X"'s. The effective range (800-1200) is more in the range where I use my truck, but you and I are using the same logic as far as application
Stock springs versus the HD's? Not a lot of difference just running straight down the highway other than when you add the King shocks, the handling, cornering, and tracking is a whole lot more responsive if you ask me. I haven't been on any trails or forest roads with it yet, so I can't comment on articulation, which is probably where the rear spring upgrade over stock shines anyway. Given my limited knowledge and based off experience, the first 1/2' to inch of travel might be a little softer on the HD's which is maybe gonna give you a little better highway ride. Just looking at the HD spring pack build compared to the stockers implies a better tuned resistance across the range of travel. Subjectively I recommend the HD over stock for how I described the use of my truck (and how I might need it to work off road). This is coming from someone who's factoring in performance with less concern for budget. I know a guy that's pretty connected and could put anything on, and he still runs stock springs in the rear and is happy with it. After almost a year on my setup, I'm about ready to throw my stock springs on craigs list if that tells you anything.
The pucks are adjustable - you just pull out the shims to get the correct height. I had to adjust when I installed the full progressive vs the HDX that was in the truck before. I guess the scenario you outlined above could be an issue still, but if I'm going to be loading up at all and not utilizing full travel I would just slide the pucks in.When I had the softer progressives with the full travel airbags and the pucks installed with a full tank of fuel and an empty bed (no shell either), I had contact on one of my pucks. No load in the bed. In my research before purchase, someone here on the forum mentioned they ran into that situation too, and that they needed to lift the truck a little to get the pucks out. It made me wonder how you'd manage if you found yourself on the road with a partial load in the bed wanting to add weight in the bed or on the hitch, and you wanted to install the pucks. You're going to need to lift the truck. I like the free travel airbags, but not cutting it that close. That influenced my decision to move up to the HD's.
