Carli Backcountry system with 37s Iconic Silver
Hello.
Finally after months of waiting I finally have everything on, well almost. What a difference the suspension makes with handling etc. I'll be towing long distance in a couple weeks so will report back again.
Goodies installed.
Carli 2.5 Backcountry system.
Torsion Sway Bar
Method 305s 20X 9
Nitto RidgeGrapplers 37x12.5
Went with Air Lift 1000 air bags on the bag.
Currently running 55/60lbs of pressure
Let me know if you guys have any questions.
Thank you CJC for answering all of my questions. :)
Let me know if anyone has questions, I know I had tons prior to deciding.
Thanks
Ryan
View attachment 12510View attachment 12511View attachment 12512View attachment 12513View attachment 12509View attachment 12508
Damn, this is exactly what I was going to do--literally exact same setup. Looks nice. I would probably run smaller wheels even though I think the 20's look nice.
How's the ride? Steering? Tuning on the foxes out of the box?
According to Carli Susp., the 3.5 lift adds 1.5” to a Tremor. I drove up on 2x8 to see what that would look like. Any reason my “scientific” approach wouldn’t be accurate?
That Antimatter Blue is rockin ???????
Stoked for you ??????✌️✌️✌️?
While the overall height is accurate, the lift is going to make the front wheel well opening larger and your tires will look much smaller. Depending on which shocks you buy, the remote reservoirs will be very noticeable with the smaller wheels. You may need to upgrade to 37s to get the proper balance of tire size to height.
What are you doing in the back? On the ones who have left the rear leafs alone, the truck has the tendency to look nose high when parked at certain angles. I prefer at least a 1” rake on my trucks to avoid the uphill look.
If you want a more accurate picture, raise the front of your truck 1.5" at the axle using a floor jack, put jack stands under the frame near the front and lower the front axle. Then, take pictures at various angles to see what it looks like from different perspectives. If you really want to get crazy, edit the jack stands out of the pictures... :cool:
PS. You have a really big garage... :)
I agree. Just like with the Toyota Tundra a leveling kit makes it look nose high. I at least want to keep an inch to an inch and a half rake. But I’d really like to do is get that block out of there when I get my truck. That has to affect the ride. Are people seeing a better ride with a expanded leaf pack instead of the block?
The Deaver progressive leaf packs remove the factory blocks and will give you the best ride quality on and off the road. However, you lose carrying capacity which requires airbags to get back to the factory stated numbers. Carli says the Deavers will have 75% of the factory capacity.
The Deaver Add-a-packs also remove the factory blocks, but do not reduce the load carrying because the factory leafs remain in place. The added leafs are progressive, but the ride quality is not quite as good as the full pack progressive leafs. Carli says the add-a-packs on our trucks with 1-ton leafs will provide a 1" rake in the back, which is about right considering the truck will still sag somewhat when towing.
I am going with the Add-a-packs because I will be towing a lot this summer and I do not want to mess with airbags. If the rake is not enough, I will add a 1/2" block under the leafs to get the desired stance.
You can also run summo springs on the extended bump stop drops with the Carli Full Progressive packs if you don't want to run airbags.
That way you can take them on and off whenever towing or not. Best of both worlds and cheaper than airbags. Lots of options out there.
I'm not going to do anything in the back right away. Your jack stand idea is a good one, but I've decided to stick to the smaller lift. Jumping up to 3.5" is too tall for what I'm looking for. Right now I'm torn between the Backcountry with the torsion sway bar or the commuter with the torsion sway bar and low mount steering stabilizer. I really like the reservoir shocks for the look, but realistically I probably don't need the extra oil. All the trails I drive are windy mountain dirt roads so I don't go very fast.
I've been having that exact debate - 37s on 18s or 20s. I've seen pictures of both on this forum and I'm undecided.
If you’re off roading I would go with the 18s with more meat on the tire.
I agree. I ordered 37x17s for mine as I want maximum rubber on my tires. There are a couple of trucks on this forum with a similar setup and I like the look.
Yeah, I'm leaning towards 18s. I do not do a ton of off roading but I think I prefer the look of the smaller wheel.
I have 17x 37s on my Raptor and the wheels look to small
we are going to sell them and get 18s and stay with the 37s unfortunately the wheels won't fit a Tremor.
Hey brother sweet truck!! So noticeable improvement without messing with the rear leafs? That’s what I’m trying to accomplish! A better on road ride with less harshness, without diminishing tow capabilities. Any improvement on those bouncy concrete freeways by any chance?
Also, did you do the Carli front bump stop extensions? Can you please do me a favor and measure them for me? I want to see how much of a drop it extends the front bump stops. ??
I think I'm changing my mind and going full progressive springs in the rear. I tow regularly, but nothing crazy heavy. If I went with the Carli 2.5 system with the full leaf springs, are you sure there is only 1" of rake? I tried to do the math myself, but couldn't. What confuses me is the Tremor comes with a 3" block I think.
Hello.
Goodies installed.
Torsion Sway Bar
Method 305s 20X 9
Thanks
Ryan
What offset did you go with on the rims? Great looking truck, going with the star white and tis 544bm
Thank you. I believe they were 18 offset. Is that an option still? Lol
