I was unable to locate any evidence.Damn, you’re up early. Keep us posted.
My burned rubber smell is always after my truck regens. the smell occurs every time after the regen
I have this both on my Tremor and on my BMW motorcycle. I ride the motorcycle in the rain an awful lot and every time I get the burning rubber smell. I've never been able to find it on the bike, haven't bothered to look for the cause on the truck.
I've got the same thing going on with my 7.3. Though it's not just in the snow. I also smell it when the roads are slushy/wet. I believe that @Vermonster might be on to something.
This is my 2nd Tremor - My first one ('21) had this smell a couple of times when it was new and then it subsided. I figured this was just new parts burn-off. I then moved from northern WY (in an area where they didn't put salt/other stuff on the road) to Northern MT (where they do put salt, etc, on the road). This is also when I sold my '21 and bought a '22.
On my '22, I didn't notice this smell quite so strongly during summer rain, however, it's much worse now that it's winter. I've looked several times to see if I can find the cause but have come up empty-handed. At this point, I've just decided not to worry about it - Though it would be nice to know the cause.
I’m having the same issue in my 22 F350 Tremor w the 6.7. Hubs are both on auto, get it after parking at the house after 20-50 mile trips. Cold, shitty weather here in WY. Now what has me curious, is I drive a 22 F250 6.7 XLT for a work pickup, same roads, same weather, hubs are both on auto, and no smell. Bought my tremor and got my new work truck both in November of 22. Both had under 50 miles when I started driving them. Only difference is, my work truck is at 10,400 miles and my Tremor is at 1,200 miles. I don’t recall smelling the burnt rubber smell on my work truck, but the roads weren’t as bad when I was at the same low mileage.
Good to know. More evidence that this is normal. Still curious what it is.I haven't noticed any smell from my 22 tremor (yet). Haven't had it very long but have driven long stretches of I80 and HW89 in snow using 4x4. However, I've always noticed a slight burning & hot oil smell under like conditions with my 06 Cummings and my 02 7.3 F250...so I'd be inclined to think it's probably normal.
Hubs are definitely in auto and no signs they're locked internally, despite the knob being in auto. Including feeling the same temperature.Check your hubs, my right one was locked and there is a rubber seal in there, throw some silicone in with your wheel off. I was having the same issue and a squeal that the service guys tracked down to the rubber ring
I doubt it, personally. No other signs of the spark plug wire failing and I haven't smelt this smell in a dry scenario, which have happened since I first noticed the smell.Spark plug wire? It’s a known issue on a 7.3.
Interesting. Were the roads wet the rest of the trip, prior to the dirt road? Or dry?I actually just noticed this smell last week, ‘22 7.3, have had the truck for since october of ‘21 and never noticed it before. I
Just got home from a 3 hour round trip, all
Normal highway driving, the last 2 miles down a snow covered dirt road.
In my case the transmission temps weren't overly hot. Certainly not more than what I've experienced in the summer and haven't smelled this smell prior to winter. I also can't imagine the transmission fluid burning off at the temperatures we're seeing. Perhaps it's bad for the fluid (not getting into that discussion hereMy 22 F250 7.3 has the same issue. Never able to smell it in the truck, I notice it when I get out. Smelled it maybe a dozen times over 16000km. It was the worst when I used the truck for an hour back and forth packing snow down for a base. I have smelled it when no snow was around to. I have not found to source yet though it seems to come from the front half of the truck. I have smelled it from my 22 F150 Tremor also. Probably burning off transmission fluid...man they run hot. The more temp in the trans the more I smell it.
I honestly think it’s snow burn off.Anyone ever track down the cause of this. I have a 2020 Godzilla and get the burnt rubber smell after braking. Only happens in slushy conditions or when it is raining or has just rained out. Only time I notice it is when I have come to a stop at a stop light or stop sign.
I have this smell all the time on my 22, and it doesn’t have be wet to get the smell. 39,500 miles, have brought it up the dealer, they know it exists but no one has been able to pin point location.I honestly think it’s snow burn off.
I have experienced this a couple times with my 2023 6.7. It was cold out and I was just cruising around town at low speeds. Shortly after I noticed it, it did a regen.I have been reading on other forums. For the 6.7 it seems to be commonly associated with the regen cycle. I know that does nothing to explain the 7.3 smells. I’ll keep following this one but for now I think Im chalking mine up to the regen.
I believe it’s the front seat warmers on high for too long causes this smell. If I don’t use my seat warmers, I don’t smell it. I believe our weight in the seat while on high heat is the key.Just happened to my '20 7.3L this past weekend. Had to put it into 4wd to climb the last 1/4 mile or so up to our friend's cabin, and when we hopped out in their driveway the smell of burning rubber was definitely present... Our '22 Bronco had this same phenomenon, also in snowy/icy conditions, so I'm leaning toward it having something to do with traction control?
I don't have seat warmers and still get the smell. I am a Pheasant. LOLI believe it’s the front seat warmers on high for too long causes this smell. If I don’t use my seat warmers, I don’t smell it. I believe our weight in the seat while on high heat is the key.
