Burning rubber smell after driving in cold and snow?
This may be completely off, so take it with a grain of calcium chloride.
‘Round these parts there are a great deal of chemicals on the road to melt snow. I mentioned one already. However, this smell you speak of I have smelled on MANY of my vehicles after driving in the snow over the years. I checked tires and belts to see no sign of anything. I’ve ruled it out to be treated slush/snow/dirt baking on the exhaust/engine/transmission/transfer case/brakes - anything hot. Some sort of chemical watery steam.
Now, I have NOT had this in the truck yet, but there has not be a great deal of snow this year. But I once ran a regeneration after undercoating - that was pretty similar, but it only lasted about two times until the “cook off” was complete.
Lastly, the only other times I’ve smelled things like this is when I am following a snowplow. They often have skids that drag along the asphalt and smell like burnt rubber. I doubt they are rubber, but some other surface that allows the plow to maintain the correct position over irregular surfaces and saves the plow from grinding away to dust. Something that tolerates heat build-up and is replaceable.
Those are my theories, my friend. Long-shot on them all, I know.
Living here is why I can’t have nice things. 40 and muddy to 33 and 7” of snow in less than 48 hours makes the truck sad.
Round these parts there is a great deal of chemicals on the road to melt salt. I mentioned one already. However, this smell you speak of I have smelled on MANY of my vehicles after driving in the snow over the years. I checked tires and belts to see no sign of anything. I’ve ruled it out to be treated slush/snow/dirt baking on the exhaust/engine/transmission/transfer case/brakes - anything hot. Some sort of chemical watery steam.
I like this theory coupled with a front differential that is actively in use and therefore, hotter than normal driving in 2wd.
I remote started again this morning and it had only been running 10 min and the smell was there as soon as I got in the truck. Heat was not cranked up yet either. I'm leaning on the belts. Gonna check as soon as it's light out and look for any abnormal wear or belt bits or evidence.
Damn, you’re up early. Keep us posted.
I've had the same thing with our Honda CR-V. So, just blew it off since nothing to be found. Go figure. Kinda like that fishy smell after it rains.
  • Like
Reactions: ccw
I got stuck once in some ice in the mountains. All 4 wheels were just spinning but I was not going anywhere. I had the rear locker on and the front two wheels were also spinning. After a few minutes one of the front wheels stopped spinning and I smelled the same burnt smell.
I think whatever the front diffs has in it got hot and started to slip making the smell. Maybe driving around in 4 high in the snow caused the same issue. I don't know if these "Tremor specific" front diffs are meant to drive around in 4 high for extended periods like the normal 4x4 trucks with just open diffs.
When my truck is in 4x4 its real tough trying to turn it because the front diff fights me. I've had other 4x4 with open diffs and they didn't fight me like this one does. I really have no clue what I'm talking about, but just throwing a theory out there.
I Googled this topic - it's nearly a question asked by an owner of every manufacture. I found Porsche, Honda, Merc, BMW, Aston Martin, Chevrolet, etc. Just in a quick Google. It's interesting.
What it shows me...we have some cool owners that keep track of their autos.
I've noticed the same thing! It's already a beast to turn around, but it fights like crazy in 4WD.
Both of your responses reinforce the fact that I'm not really worried about this smell, mainly curious.
I think we should end the mystery, though. There has to be some chemical reaction that causes this. Too mad MythBusters is not still filming.
  • Winner
Reactions: ccw
I have this both on my Tremor and on my BMW motorcycle. I ride the motorcycle in the rain an awful lot and every time I get the burning rubber smell. I've never been able to find it on the bike, haven't bothered to look for the cause on the truck.
It's just the organosulfur and oxygen molecules in the gear oil reacting with the compounded rubber and asbestos in the differential friction plates, catalyzed by heat...
You've been holding out on us, Mr. Wizard.
I haven't noticed any smell from my 22 tremor (yet). Haven't had it very long but have driven long stretches of I80 and HW89 in snow using 4x4. However, I've always noticed a slight burning & hot oil smell under like conditions with my 06 Cummings and my 02 7.3 F250...so I'd be inclined to think it's probably normal.
Check your hubs, my right one was locked and there is a rubber seal in there, throw some silicone in with your wheel off. I was having the same issue and a squeal that the service guys tracked down to the rubber ring
I've got the same thing going on with my 7.3. Though it's not just in the snow. I also smell it when the roads are slushy/wet. I believe that @Vermonster might be on to something.
This is my 2nd Tremor - My first one ('21) had this smell a couple of times when it was new and then it subsided. I figured this was just new parts burn-off. I then moved from northern WY (in an area where they didn't put salt/other stuff on the road) to Northern MT (where they do put salt, etc, on the road). This is also when I sold my '21 and bought a '22.
On my '22, I didn't notice this smell quite so strongly during summer rain, however, it's much worse now that it's winter. I've looked several times to see if I can find the cause but have come up empty-handed. At this point, I've just decided not to worry about it - Though it would be nice to know the cause.
had a f-150 that the vent tube was blocked for the front differential. ended up cooking the gear oil and gave a bad smell, but i wouldnt say it smelled like burnt rubber.
  • Wow
Reactions: ccw
Man - gear oil always smells nasty to me.
I’m having the same issue in my 22 F350 Tremor w the 6.7. Hubs are both on auto, get it after parking at the house after 20-50 mile trips. Cold, shitty weather here in WY. Now what has me curious, is I drive a 22 F250 6.7 XLT for a work pickup, same roads, same weather, hubs are both on auto, and no smell. Bought my tremor and got my new work truck both in November of 22. Both had under 50 miles when I started driving them. Only difference is, my work truck is at 10,400 miles and my Tremor is at 1,200 miles. I don’t recall smelling the burnt rubber smell on my work truck, but the roads weren’t as bad when I was at the same low mileage.
  • Like
Reactions: ccw
My burned rubber smell is always after my truck regens. the smell occurs every time after the regen
