Brake upgrades?
Definite upgrade in performance
If you don't mind what kit number did you actually use I'm having a hard time finding the one that fits our m275 rear axle that is in the tremors
I wish this truck had paddle shifters.
It can! 🙂
Late in responding but I had an experience on I 90 when traffic suddenly came to an abrupt stoppage and I pressed firmly and my Tremor did exactly what I was expecting. No tire skid, just a solid stop. The guy behind me, also in a Ford truck (do not know what year) burned rubber trying to avoid me and angled for the median. Luckily no collisions occurred. But I’m pleased to say the least.
I was having similar issues, 2020 with 6.7. I got rid of the OEM tires, now running on Toyo Open Country M/T, much less less noise. I lowered the rear tire pressure, matched the fronts @ 60 PSI. The ABS doesn't kick in as much as before.
Blast from the past!
I ended up installing the full Powerstop brake kit front and rear.
I also now have the E-Venture suspension with braking sensitivity set to maximum, and I replaced the Duratracs with Ridge Grapplers.
The feel of the truck under heavy braking is remarkably improved.
Now you just need the raptor steering wheel swap for your paddle shifters and you’ll be all set! Glad you finally joined the e-venture team!
How do you adjust braking in the e venture I’ve not seen that yet
I missed it, apparently powerstop brakes are the “best” ones to upgrade to?
I’m not loving the mushy feeling when I brake
I put powerstops on my ram. Its brakes were pretty bad. I did the pads, rotors and calipers. The oem calipers on the rams need to be done with every brake job. The ones from powerstop were oem ones that were rebuilt with better than oem parts. Anyone who’s installed the powerstop brakes done the calipers as well? Are they rebuilt with same as o‘‘em or better than oem? My ‘99 F150 went over 200k miles without needing the calipers being rebuilt, but the ram couldn’t go 40k miles without needing them rebuilt. The red calipers do look cool.
In the pro settings, you can adjust it such that it stiffens the front shocks in response to braking. I doubt this improves braking performance per se but it reduces nose diving which sure improves the feel.
I don't know of any better option available for this truck. They're a relatively minor upgrade, but for the money they're well worth it, IMO. Most of the performance is probably coming from the pads and SS lines, with the rotors seeming to help when doing a lot of heavy braking (in the mountains, on the trail, towing, etc.) A nice side-benefit is there's a lot less brake dust to deal with.
Would buy again.
My understanding was that the calipers are the same as OEM, just painted. So I abstained.
Not sure if anyone has mentioned it yet and I have no experience just been eyeing them since hearing SDHQ talk about them in a video is EBC brake and rotor kit. From researching they also look to be a solid product.
What does upgrading to stainless steel brake lines accomplish?
The rubber OEM lines or any rubber lines for that matter absorb some of the applied pressure because rubber flexes, the stainless steel lines don't flex (or very minimally) resulting in more pressure applied to the pistons in the caliper thus more stopping force applied to the rotors.
Agree with the theory here, but don't go cheap if you get SS lines. Coming from car/track experience, there are many offerings out there that are worse than the OEM lines for feel and durability. You don't want to trade one issue for another!
Don't be that guy who always has to pile on with one more thing... Wait... I keep forgetting... that is what we do here!! 💰 💰(y)🍻
If that steering wheel thread wasn’t so overwhelming I’d have bought mine by now.
Bumping this thread
Gonna do a pad and rotor swap.
Doing the front and rear. Prefer slotted over drilled. EBC Yellow stuff. Seems like it should help quite a bit and get get of the annoying squeal I've had for the past 2 years from the front brakes.
Bumping this thread
Factory pads?
