My Hypothesis is that you are right about EPA mandating positive pressure for emissions. Unburnt fuel (black smoke) was a huge issue with older mechanical diesels. That positive pressure ensures complete combustion even at idle, which is why modern diesels run so clean visually. But complete burn ≠ maximum efficiency, and here's where it gets really interesting.
Just dove into some technical literature on this topic, and we're both right! But, looking at different parts of the system. From pure piston thermal efficiency (Carnot cycle), I'm correct, boost at idle creates parasitic pumping losses because the VGT vanes are closed. The turbine becomes a restriction that costs us 3-5% efficiency. BUT, and
this is the key, that boost prevents wall-wetting where fuel droplets hit the cold cylinder walls. Without boost, the fuel spray over-penetrates, creating white smoke, oil dilution, and massive PM loading that would trigger a DPF regen cycle. So you're right that boost improves combustion efficiency, just not thermodynamic efficiency.
Your AFR numbers are spot on for power: 14-16:1 (the "smoke limit"). Efficiency peaks at 20-25:1 like you said, but at idle these things actually run 30-70:1 AFR. Way leaner than either of us thought. You're also right about NOx going through the roof at those lean mixtures, the Zeldovich mechanism kicks in above 2000K.
The 1-2 psi boost at idle is primarily about keeping the SCR catalyst above 200°C. The closed VGT vanes creating backpressure convert pumping work into exhaust heat. Without this, the SCR drops below light-off temperature and violates the 30 g/hr Clean Idle NOx mandate. It's deliberately running inefficient locally to maintain system-level compliance.
Injection timing between P and D: Research shows opposite what what I suspected
- Park/Neutral: Retarded timing (near or after TDC) for NOx control
- In-Drive: Advanced BTDC to counter converter drag, So you might see more than 2-4 degrees difference
PTO in Park: yes, most Ford PTOs can operate in Park or Neutral. The PTO ramp-up question is interesting, my guess is the ECU has separate calibration maps for PTO mode that pre-spool the turbo or accept a brief rich spike? Would be fascinating to log VGT position % during PTO engagement. I soooo wish I would have spent the $300 for the PTO option and have an killer electric generator right now.
The bottom line: Modern diesel calibration accepts a constant efficiency penalty at idle to prevent 2000°F DPF regeneration cycles that would cost way more fuel. I'm looking at piston efficiency, you're looking at system efficiency. The engineers chose system efficiency, which is the call for emissions.
I too love the applied theoretical conversations! And you have the best viewpoint, the ability to change your stance given conflicting information is sadly a lost skill. Too many people cite experience on the wrong cycle (looking at you, Brayton cycle guy) or pure seat time without understanding the physics. Learning car shit with a heavy side of science and engineering is the way!
If you're into a deep read here is Gemini 3 deep research that scoured the web (for duramax however? The interesting question which cult has the bigger scientific population?)
https://gemini.google.com/share/d6fb702344b8
