Blower Motor Speed Problem
LetEmRun
Tremoraholic
Idaho
2022 F350 Tremor 7.3L
Starting a few weeks ago, my blower fan works appropriately in modes 1-6. When I go to highest setting (7) there is no change in airflow. I had one day where it started working again but now it’s been a problem for weeks.
Any ideas?
Cabin air filter comes to mind....
Filter is about 2 months old. There is zero change in the fan speed when going from mode 6-7. Basically the motor seems to not be getting a signal to change speed.
My wife's jeep liberty had a motherboard that got corroded and lost 2nd and 3rd speeds. Can't remember what it was called but it was just behind the glove box. Simple fix. Maybe Ford has a similar deal?
Blower motor resistor...
Pretty sure the fans in these trucks are PWM controlled now which would make this issue even more interesting. Not sure when they went to PWM, though. May have been in 2022 or 2023.
Edit: looks like they may have gone to PWM as far back as 2017.
  • Love
Reactions: McE
Interesting. Will have to research that. Thanks
googling PWM now :unsure:
Ah im talking the cabin blower motor. I think you are referring to the engine fan
Nope, engine fan is mechanically driven with a (poorly designed) clutch mechanism. HVAC blower is electronically controlled using pulse-width modulation or PWM for speed control.
Not to say your motor isn't stuck at 6, but changing a filter based on time is about as reliable as predicting six more weeks of winter by a groundhog's shadow.
Change it based on usage and the environmental conditions. At the very least, inspect it periodically instead of relying on a set time. Filters don’t have a clock that rings a bell when it’s time to change them.
I wish mine would have pulled my hair because it couldn't take on anymore, after I neglected it a little too long. This was roughly two months...
Interesting. I’ll have to keep researching. From what I’ve seen, sounds like the resistor
Your truck doesn't have a resistor but it would be a hell of a lot easier to troubleshoot if it did. The blower is controlled by a PWM signal, not a resistor pack like the older trucks. Technically, there's a module that sends a PWM signal to another module that then uses the PWM signal to modulate the ground side of the blower motor circuit. 🤓
It's likely either an issue with the FCIM (Forward Controls Interface Module) that sends the PWM signal to the blower motor speed control module or the speed control module itself. The speed control module (which is what people often and incorrectly call a "resistor") uses the PWM input from the FCIM to modulate the ground side of the motor circuit. Very unlikely the wiring or blower motor itself is bad if it functions normally in speeds 1-6. To troubleshoot, you'd need to back-probe the PWM signal wire (should be a 0-12v square wave) from the FCIM to the speed controller with the positive probe on your meter. Should be the violet/orange wire but verify that in the service manual or with Alldata or something. Negative probe on the meter should be to chassis ground. You won't be able to see the actual waveform of the PWM signal without an oscilloscope, but you should be able to see a slight change in voltage between settings 6 and 7. If you don't see a change in voltage, it's likely an issue with the FCIM. If you do see a change in voltage but still no change in fan speed, it's more than likely a bad speed control module. The speed control module is cheaper.
You could use Forscan to restore the FCIM using as-built data and see if that fixes it first. A dealer can use FDRS to see a logical representation of the PWM signal directly via the CAN bus if you don't feel like trying to troubleshoot it yourself.
Hopefully at least some of the word salad above is helpful. Keep us posted!
Wow. Thanks for all the info. I think I will have to read that a few times to make sense of it 😊. Appreciate the help
