- OP 🔹
- #61
Thanks MattR. Which kit components did you go with for your set-up?I just installed a 2.5” OUO kit and it rides better than stock. The rear still needs a little work but I love the way it rides for a 3/4 ton.
Track Rod Bracket [Included]: #105017 Track Rod Kit Bracket, 2.5in Lift, Track Rod [Included]: #105068 Adjustable Track Rod, 2017+ Superduty, Sway Bar Relocation Kit [Included]: #105029 Sway Bar Relocation Kit, 2.5in Lift, Bump Stop Drop [Included]: #101366 Universal Bump Stop Drop Kit, 2-1/2" [Needed], Coil Levelers [Included]: #105020 Adjustable Coil Levelers, 2.5in Lift, Steady Track™ Bracket [Included]: #105101 Steady Track High Mount Steering Stabilizer Kit, 0-4.5in Lift, 2020+ for Fox #983-02-14 3, FOX ATS [REQUIRED FOR STEADY TRACK SYSTEM - BUT YOU CAN SOURCE FROM ANOTHER VENDOR]: #106209 2017+ SD ATS Stabilizer (983-02-143), Radius Arm Drop [Included]: #105107 Radius Arm Drop | 5 degrees castor at 2.5in lift., Shock Extensions or Shocks? - Shock Kits Include Front and Rear Shocks: #105074 2in Tall Front Shock Extensions [FOR USING STOCK SHOCKS ON 2.5IN LIFT],Thanks MattR. Which kit components did you go with for your set-up?
The tune in the Pintops is optimized for the full leaf springs - it's the spring option that will perform best with the Pintop but it's not necessary; ride will suffer slightly but a Tremor will maintain a slightly rear high stance even with stock springs.are the rear springs necessary with the pin top kit if staying level?
Went with One UP Off-Road Steady Track High Mount Steering StabilizerHi all- Hope everyone had a Merry Christmas.
I wanted to get some feedback from various users on leveling suspension systems for a 2022 Tremor. I know many on this forum have gone with Carli (mostly backcountry) and a couple who have gone with One Up Offroad (2.5" Steady Track). These are the same systems I'd like to consider.
I thought my mind was made up that I wanted to go Carli until a friend put a pintop kit and 37's on his 2023 F250 and has had nothing but complaints on the ride. With my 22 F250 Tremor, the use is mostly freeway / town miles with minor offroad (I'm a contractor, so it sees jobsites daily), and occasionally pulling work / camping trailers. I'm looking for the best feedback for ride quality and leveling to run 18-20x9-10 wheels and 35 or 37 inch tires (Falken, RT's, AT3's likely).
I've read thru most of the forums on suspension, but this comparison I haven't found much of. Any feedback would be appreciated. Thank you.
So sick!!!Went with One UP Off-Road Steady Track High Mount Steering Stabilizer
Kit, with traction bars and full pack Deaver springs for 4.5in Lift using Fox 2.5 elites with Icon progressive coils.
Suspension very solid from commute to aggressive country road driving with Hwy driving very smooth.
The coil ring was at the very top of usable treads, so we decided to try Eibach Coilovers 24" at 350 lbs.
Even though, either selection of coils is good off-road, we feel the truck had more stability with the Eibach Coilovers and felt little like a motocross suspension in the front, going fast off road. It's interesting that the first 2" to 3" of front suspension travel feels like a 4-link but has the handling of a Radius arms.
On the rear full pack left springs acted as expected (Note: All of our Super Duties had full pack Deaver left springs) which is great, However, when we added the one up off-road traction bars, it made a world of difference. We noticed the rear braking stopped harder, hard acceleration is much smoother and less (hard to describe) rocking when rock crawling. Dave might be able to explain better than me.
The Falkin Wildpeak RT 38x13.50R17LT rides great at all speeds and has very good grip on rocky ledges.
Btw, tire psi of 4-6 lbs. highly affects how this truck feel both on road and off.
They don't post what their spring rates are, but assuming 5200-5600lbs as is common with most diesel coils (translates to about 450 lbs/in deflection each) 0.5" is a reasonable ballpark estimate with an engine that weighs ~500lbs less than the diesel.I've tried several searches and perused multiple threads, but haven't seen this specific question answered. If anybody knows the answer I would be grateful.
Exactly how much front lift (either hub center to fender or frame to axle) do the Icon 2.5" coil springs (#62511 20-22 FSD 2.5" DR coils) yield on the gas Tremors? Nobody at Icon seems to know for sure. I assume another .5" more than on a diesel, but??? Thanks in advance.
Also on a strange side note, the girl I just spoke with from Icon claimed that these two springs (#62511 & 62513) are actually the same. Unless Icon's Tech Notes at the bottom are false, I don't see how. I also thought that the springs would be interchangeable between 22-23. Carli's 2"/3" leveling coils claim to fit FSD between 2011-2023.
GRRR help!
I can’t speak for Icon coils but the Carli diesel leveling coils brought my 7.3 Tremor up 2 5/8”. Betting the icon will be very similarI've tried several searches and perused multiple threads, but haven't seen this specific question answered. If anybody knows the answer I would be grateful.
GRRR help!
Did you keep the rear the same? Trying to decide between 2.5 or 3.5 coil for the front. Don’t want a reverse rake.I just installed a 2.5” OUO kit and it rides better than stock. The rear still needs a little work but I love the way it rides for a 3/4 ton.
Yep. It's almost exactly level, within 0.1" or so. The OUO kit has adjustable coil spacers so you can adjust as neededDid you keep the rear the same? Trying to decide between 2.5 or 3.5 coil for the front. Don’t want a reverse rake.
I’d like to see!! Mine is 0.5” higher in the back and sometimes looking at it, it looks rear low. Doesn’t bother me but just curious if yours appears the sameYep. It's almost exactly level, within 0.1" or so. The OUO kit has adjustable coil spacers so you can adjust as needed
MatttR- I saw your response in another thread suggesting Carli for similar reasoning to what I'm asking about.Track Rod Bracket [Included]: #105017 Track Rod Kit Bracket, 2.5in Lift, Track Rod [Included]: #105068 Adjustable Track Rod, 2017+ Superduty, Sway Bar Relocation Kit [Included]: #105029 Sway Bar Relocation Kit, 2.5in Lift, Bump Stop Drop [Included]: #101366 Universal Bump Stop Drop Kit, 2-1/2" [Needed], Coil Levelers [Included]: #105020 Adjustable Coil Levelers, 2.5in Lift, Steady Track™ Bracket [Included]: #105101 Steady Track High Mount Steering Stabilizer Kit, 0-4.5in Lift, 2020+ for Fox #983-02-14 3, FOX ATS [REQUIRED FOR STEADY TRACK SYSTEM - BUT YOU CAN SOURCE FROM ANOTHER VENDOR]: #106209 2017+ SD ATS Stabilizer (983-02-143), Radius Arm Drop [Included]: #105107 Radius Arm Drop | 5 degrees castor at 2.5in lift., Shock Extensions or Shocks? - Shock Kits Include Front and Rear Shocks: #105074 2in Tall Front Shock Extensions [FOR USING STOCK SHOCKS ON 2.5IN LIFT],
I have the stock shocks but debating on changing them out as I keep reading stories of them leaking. Will probably just do Fox 2.0 resi
So the OUO drives really well, but it’s a little bumpier than the Carli kit. I expected that, as the point is this kit is to maintain payload and towing. I did his leaf spring shims and it loosened the rear up a bit, but might end up doing PMF Deavers with airbags in the future. My friend has a backcountry Carli kit on his 24 and it does ride smoother over bumps, yet other areas seems to ride worse (bumpsteer etc).
What'd you get??Ended up going Carli…
I stand by my statement above - these premium aftermarket suspension systems don’t do anything worth mentioning for the on-road, on-pavement ride. That is what i said above. At best you will be able to track straight and vibration free with your glorified lift, if lucky from defect or installer issues. Off-road you can do better than oem with a carli, but lets be honest, most who purchase these systems spend majority of their time on-road.
I sold my previous gen truck for one simple reason - carli full catalog on it and what it did to the truck. After a year of dealing with issues and throwing thousands of dollars (over 20K total invested) and my time trying to fix it i gave up and dumped the truck.
At this point i no longer trust anyone’s suspension advice on the forum (unless its keeping the truck suspension oem), and i don’t care how many Xs will come and say how their carlis and ouos drive 100% better.
That is all i’m going to say on this topic.
There is one post thats worth gold when it comes to advice for someone considering fucking with OEM geometry and it is this:
Regular Super Duty vs Tremor
I see a lot of people on here upgrading their suspension. Isn’t a better suspension the main part of the Tremor package? If that’s so, wouldn’t it be better to get a regular SD and do the Carli, or other brand, of suspension upgrade?www.fordtremor.com
