I think it depends on a lot of factors. I reject the notion that "nothing can be done" but most of it still comes down to each individual user. I've already shared a lot of my personal experience running a Pintop on my own truck in this thread and others, but some of it bears repeating, in summary when I'm alone in the truck I'm aware of the tighter ride but it doesnt really bother me. When I have passengers though I become a lot more aware of how bouncy it is over smaller imperfections on the highway.I could be 100% wrong here but I truly feel like my truck feels substantially better than it did before.( Going from the commuter to the Pintop) I feel like things that would usually cause jarring in my truck with the commuter kit no longer does. I was truly nervous putting these shocks on my truck because I figured if it was in fact worse than the commuter kit I was going to hear it from my wife
So I am curious if it is one of two things. The first is that the nitrogen pressure needs to be set appropriately. I have seen several pintop owners figure out that they had the wrong pressure in the shocks which caused a stiffer ride. The second is that maybe I drive my truck a little harder than I should on the street which lends itself to a better experience with the kings compared to the fox 2.0.
I guess I keep looking for a harsh response but I am not seeing any signs of that except in my rear springs.
I do enjoy this conversation because I do believe that I am learning more and more every day from each of your experiences. So I thank you for your input.
For anyone not local, the highways out here arent paved in asphalt, they are laid down as slabs of concrete which over time shift/settle and create a fairly uneven surface that in a heavy truck is absolute hell to drive on. The stiffness of the Pintops seems to amplify this and at speed the truck picks up a sort of resonant bouncing motion as the lengths of the slabs seem to almost perfectly match the wheelbase of the truck. It's mildly annoying when I am alone but borderline intolerable with passengers in the car. As an example (and one of the reasons I am contemplating upgrading to an E-Venture system) back in November I was driving to the airport with a friend who was recovering from a recent medical procedure that had required an IV port in his upper chest/shoulder area and he actually had to slide his hand under the shoulder belt and hold it away from his body (and asked me to slow down a little) because this bouncing motion was irritating the spot on his shoulder where the IV plug used to be and was causing a him a fair amount of pain even though the plug had been removed over a month prior.
Some of this can be mitigated by getting the right suspension system for your own use case, but a lot of it is unavoidable because of what the truck is; heavy towing and hauling require high spring rates and heavy duty shocks to control the loads. To soften the spring rates and shock valving enough to eliminate all the bouncing then you'd just have a bigger, heavier, and slightly less useful Raptor with severely compromised towing/hauling capabilities. FWIW, stock my truck drove like absolute shit through the same places the Pintop struggles.
