Battery Upgrade - Odyssey ODX-AGM65 (65-PC1750T)
I know I'm reviving an old post, but it's funny seeing these batteries go up 25% in price in 8 months.
""Remote features disabled to preserve battery"
That was a bug in the app that was fixed in a recent update. Was in the notes for the patch.
Was it? I still get spammed with these messages in my Fordpass app and it shows I have the newest update.
V 4.18.1 fixed it
It says "update corrects oil life errors and intermittent remote command errors for customers who have more than one vehicle"
I have only 1 but still got the errors. Once I updated, it went away.
Version that broke it was V4.18.0
Current version is 4.19.0
V 4.18.1 fixed it
Ah ok, looks like I have v4.18
But also doesn't show there is an update for it (on Android anyway) bummer.
I wonder how many batteries Ford sold with that error. Took them a week to fix it
Just installed two of these since I got tired of cleaning battery residue.
Changed FORSCAN setting from Flooded to AGM but curious if anyone has changed the Battery Target State Of Charge % setting? Mine is set at 120% from factory.
Not sure if this is where you take static charge of 12.8V and target charging V at idle of 14.4V If this is the case, I think 112% would be the setting.
My factory state of charge was set at 120% and I changed it to 95% when I installed my Odyssey AGMs a couple weeks ago.
Just replied to your build thread while I was searching. Anything noticeable with yours being 95%? What made you decide 95% instead of 100%?
I would like to see a screen shot of the Forscan lines you are changing. Pretty sure mine said battery target state of charge 80%.
Pic from another forum. The 2022s come set at 120%.
Mine was originally set to 120%. I set it to 100% after switching to agms.
Wasn't sure, but I know agms are more sensitive to overcharging.
Just checked our 2019 Expedition with AGM and Auto Start/Stop and it’s at 80%.
i went into the truck and set to 100%. I would be curious if someone set their flooded batteries to 100% if that would fix the leaking.
100%, pretty bold ;) Was hoping you'd join the 95 club lol.
I changed my battery to AGM a year ago and did not make any changes to the computer.
Curious for those that have changed to AGM batteries and have modified their settings.
What voltage are your batteries measuring after the truck has been off for a few hours?
I measured mine with a multimeter and I'm seeing about 12.72 volts from battery 1 and 12.69 volts from battery 2, which seems a little on the low side (I've read 12.8v is considered fully charged for an AGM battery)
Thinking about changing my charge state back to the default value.
I set mine to 102%. I still have factory batteries (2750 miles). We'll see if any leakage starts.
Update-
Little over two months and 2400 miles, and there is absolutely no battery acid leakage visible on either battery. I'll go another 2500 miles and check it again. Appears the lower setting helps.
