I would have to presume that using Forscan to change the BMS from flooded to AGM would likewise change the charging profile as they are somewhat different (otherwise why would it need to be changed).
To the point of differing charging profiles, if you get a battery minder be sure and get one that is appropriate for your type of battery. AGM's require a final voltage that is higher than flooded. A minder for a flooded battery will not fully charge an AGM and an AGM minder will slightly overcharge a flooded battery.
And speaking of charging batteries and BMS systems, does anyone know if the following F-150 precautions apply to the F-205's?
