Banks 5" Monster exhaust need help
Any reason to not just put the tip on if the full exhaust doesn’t do anything?
going up from 3 1/2" to 5" is suppose to help reduce the temps of the exhaust.
Not sure about any of the sound difference thats a huge debate, but it gives my Tremor more of a custom look
Interested in hearing from anyone who has done the 4 and/or 5 inch Banks exhaust mod on the 2023 6.7L Tremor.
Any challenges with the install? Contemplating the 5 inch if fitment is good.
I have it on my '23 F250 Tremor with the 5th wheel prep, no issues.
View attachment 46065View attachment 46066View attachment 46067
Plenty of space between the pipe and the spare.
After ALLOT of measuring and test fitting, I ended up making the new pipe the same length as the intermediate pipe I removed from the truck. NOTE: THIS IS *NOT* WHAT BANKS SUGGESTS, BUT WHAT I FOUND WORKED BEST FOR MY SITUATION AND THE FITMENT ON MY TRUCK
The only "tight" spot I had was where this hanger (center in pic above) came close to the cross frame support when it was pushed toward the front of the truck.
dang those are good pictures. awesome !!
after install I have the pipe clamps bottomed out and tight but can still rotate the pipe
Has anyone T&D their truck and kept their 5" Banks Monster Exhaust? I know that you can get a 4" race pipe that will just bolt right up, but I want a full 5" and would rather buy an entire 5" straight pipe and join them at one of the joints. I already have the Banks system on it and love how the tip looks and the alignment of the the tip with the body.
You can run a dpf delete pipe into that rear section of the banks kit. They bolt together perfectly. A complete 5 inch kit is only 5 inch to the trans support bracket, then it necks down to 4. You will gain about a 2 feet of 5 inch pipe at the cost of around a grand to go that route. I run a 4 inch stainless dpf delete pipe into my old dpf back mbrp exhaust. I use the turbo as my muffler. Sounds great, not too loud, no drone.
Most all the 5" kits use a 4" down pipe, then expand to the 5" piping once under the truck (as @Explorerinil noted). Not worth it in my mind aside from changing the tone of the exhaust. No one here is going to push hard enough to "use" the capability of true turbo-back 5" system.
I'll be using a 4" race pipe that goes to the MagnaFlow 5" DPF (or over axle ) back kit.
:cool: :cool: 🇺🇲 🇺🇲 🇺🇲 🇺🇲
Thanks for the honest review of the sound difference.
You would have to cut the flange off just farther back at the 5" section and use a band clamp to hold them unless your 5" section is meant to work with stock back section. I'd advise you to leave your under truck section longer (usually the exhaust have a trimmable section meant for various bed configuration) and I wouldn't trim that till you trim off the dpf back section accordingly (again uhh bless it necks down to factory flange and you want to keep that). I would try to get it flaired for slip and better sealing with band clamp.
Ive seen 4" sections that do that but not sure about 5". For factory dpf back sections.
A straight 5" will be louder and have more drone esp when towing but you may not notice or care or can add a muffler later if it bothered you.
