Baja Designs Projects.
Which mount? I purchased the scratch and dent version from GJ which was alot cheaper and sourced the Baja lights myself. My mount had a run in the powder coat which is only seen on the back back of the housing not visible from outside. it cost me $220 with the standard harness. I did the Sports not the Pros for the brake light.
looks like their out of stock on the scratch an dent, but keep checking..
I just built it out with the lights and wiring harness.
Starting my Baja Designs project.
First is the 3rd Brakelight from GJ Motorsports w/ 3 @Baja Designs Sport. Amber lights are Driving/Combo and Center Cargo light is white Spot
Next project is Baja Designs Pro S2 Amber Driving Combo flushed in the pocket below the factory fog lights. Here's a mock up.
Last Baja Designs Mod for now is the Linkable 7XL Light Bar, on order just waiting for it to come in!
Stay tuned!
Do you lose bed camera. I may have missed answer if you had posted this already.
yes you do, but I don’t need the bed camera since I have a cover on the bed and no 5th wheel to worry about
Thanks for that. I’m needing the camera. But it’s an awesome setup. So classy and slick
Wired up the rear ambers today.. Found the up fitter passthrough wiring, but the wires inside the cab are just way to short to work with without taking everything apart. The other end you can grab easily and work with by removing your wheel well liner. I found a existing empty slot/hole next to where the orange antenna wire runs which is covered by a black tar/sound deadening material. I used my step bit and enlarged it slightly which worked perfect for my harness to run through finished by a rubber grommet. Ran to AUX 3 on the blunt cut wire harness under the hood and worked out perfect.
here's my finished wiring..
Will post pictures of the Front Linkable XL lights tomorrow after I install them.
wiring turned out pretty clean! Still haven’t tackled the XL lights yet, ran out of time this weekend.
might try next weekend but looking forward to seeing your install!
Stay tuned!
Did you already finish the Pro S2 Amber Driving Combo flushed in the pocket below the factory fog lights? I did not see those pics. Really interested to see how that turned out.
Got the light bar installed. Very happy with the result! couldn't trim the plastic end caps or cut in the fogs tonight because my Dremel tool battery took a crap so I need to get a new one tomorrow to finish. Having some professional photos taken this weekend!
The lights on in this photo are just the headlights and not the @Baja Designs XL lights.
really fits the color way of you truck well.
think it looks ok without the trim piece to be honest
One down... there is very little room for forgiveness behind the light with metal bumper supports so take your time. @modified i used a dremel tool
