Axle recall repair/replace
It’s common for paint to be missing from the factory. Best guess is it’s a result of how the tooling holds the axle while moving it around.
Obviously paint missing could be an indicator of flexing, but I suspect missing from the factory due to handling is more likely.
Here’s a pic of my axle before I left the dealer lot. (22MY 7.3, so not a part of the recall in more ways than one, but proves the point).
Thanks for the pic... I uploaded pics on the other axle weld thread and they look like this at 5000 miles. A little bit of reassurance helps...
Does anyone know how long you have to get the recall work performed? I really don't want anyone messing with my truck. For example taking off my axle and everything attached to it, repairing it (welding) and then putting it back together (hopefully the same way). I think my preference is to just hang tight until I see some damage or wait until more feedback from repairs are available and dealers or their vendors have done these repairs long enough to where I feel competent letting them "fix" it. I don't like being without my vehicles! I still haven't got the windshield recall done yet either because of the downtime needed.
I have been waiting 7 weeks for the parts to be shipped to my Ford dealership so they can perform the (weld repair) on the axel. They keep telling me probably next week. I don’t think they have a clue when it’s being shipped. I had to cancel my reservation at the 1st campground, in three weeks I’ll have to cancel another. Pay 81k for a heavy duty truck to haul my 5th wheel and can’t use it. Totally pissed off.
Captain, did your dealer inspect yours and tell you not to drive it? If not then I would go on your trip and just keep it at 65 or less.
If your pin weight is less than 2500 lbs I wouldn't worry about it.
The dealership said I can use the truck but not tow anything. They said if I choose to use it for towing and something happens Ford will probably throw it back on me because I was aware of the issue.
The made it clear they (the dealership) don’t recommend towing until repair is completed.
My truck has been sitting at the dealership for 3 months. Every time I call or stop by for a update they tell me they extended my rental for another month. The service department inspected my truck and it failed so I was told that they would have to take me out of the truck.
I have been trying to order a new 2022 but it's like the salesman doesn't want to be bothered with it. Very Frustrated.
I have been trying to order a new 2022 but it's like the salesman doesn't want to be bothered with it. Very Frustrated.View attachment 39088
I’d ask for 3 months of credit. Did you finance through ford?
No I did my own financing. They did give me a F250 Lariat for my rental though.
Then request a extended warranty. Being unable to drive your truck for 3 months is unacceptable. I thought the lemon law buy back starts at 30 days of it not being usable
Here are a few pics of my F350 axle. I took this the day before it went to the shop.
Here are a few pics of my F350 axel. I took this the day before it went to the shop.
In the 4th picture it looks like the original weld broke free on the end? Is that true? Otherwise to me, from the pictures and my lazy boy it looks like you just need the additional welding done not a whole new axle set up. 🤷‍♂️
The mechanics in the shop went through the procedure that ford has out for the recall. It said if a .002 feelers gauge would slide between the perch and axle tube it fails.
I understand all of that and what the procedure entails. That’s why I asked if the weld started to separate or something. Because like I said from the pictures you posted and from me sitting in my lazy boy (not under your truck) I don’t see any gaps. I’m just trying to make sure you are not getting messed around when you could be driving your own truck. I have yet to take mine in for this recall because of what you are going through right now.
I called Ford customer service yesterday and filed a claim for buy back, lemon law. They gave me a case number and said they would contact me in 7 to 10 days. I’m sure it will be a denial. Nothing has worked out with this truck since I bought it.🙁
Update on my truck.
11/16 - Called Ford and filed a Buy Back Claim.
11/23 - Ford called and said the parts to fix my truck would be at the dealership Friday the 26th.
11/23 - Called dealership to confirm parts shipment. only axle housing would be there not all the u bolts and nuts (backordered).
11/26 - Ford called to inform me that my buy back has been approved.
Now to start the process of ordering a 2022 F350 Tremor. I hate the thought that I could possibly go through this winter with no truck.
Update on my truck.
Good because that’s just not right. They know the laws and figure we don’t. Over 30 days out of service is not acceptable. I’m glad I talked you into it.
I am looking at a used 2020 Platinum that is affected by the axle recall, do you guys suggest to stay away from it and move on ? My main use is with a Nothern Lite 2800lbs slide in camper
Check the build date. If it was built before 08/06/2020, you are good, as it was after that date that Ford or Dana decided to make the M275 with thinner tubes. All trucks with the M275 built before 08/06/2020 and built after 05/15/2021 have thick axle tubes and will not have this problem.
personaly i certainly wouldnt want a thin wall axle truck and im not sure i would even want one of the later built.ones. theres a guy on youtube that had his thin wall collapse so he cut the tube in half and going off old memory it seemed like they were only .140 thick or so. when his updatex axle showed up it seems like he measured thickness through the vent tube and it was only about .180 so not much more. again this is old memory as it was a couple yrs ago when i seen the vid but it didnt seen like they beefed up the tubes much at all. probly just enough to stop collapsing
