My understanding is that it was Dana producing them out of spec. Ford's design was for consistent wall thickness.
Exactly my thinking, not sure what to do here. Now have a truck made to tow with a thin walled axle that I’ll be nervous anytime I hook up..and they want to do a weld which I don’t believe is a safe or sufficient fix for this issue
I wondered the same thing, so I ordered a 22.
I am not a fan of the fix.
welding between the points that are bending doesn't make any sense. the only way to distribute load is to make the patch bigger not bridge it in between.
So long as there is no initial deformation, I would have 0 reservation about accepting and having faith in the fix. Further, for these axles to deform, in my opinion, a person would need to be towing close to max if not over constantly. I could be wrong here though.
I've towed with the gross trailer weight of 12K quite a few times and my axel is still true.
I'd personally rather see a reinforcement plate, but an extra weld should suffice.
Also, if Ford doesn't eventually expand the recall to all M275 axles, I'm sure a class action suit will come around.
On a similar topic, do we know if the defect is due to Dana producing them out of spec, or if it's an issue with Ford's original design specs?
After reading the TSB 21S31 and threads on other forums, it is my understanding the 6.7L trucks were going to get 'new' tubes (whatever that exactly and precisely means - hope it means "new full thickness tubes"). I have not found any concrete information on axle tubes used on 7.3L trucks built after the May 15, 2021 recall date.
Hopefully, the 7.3L trucks built after the May 15, 2021 recall date have axle tubes with the same wall thickness over the length of the tubes.
IF the 7.3L trucks built after May 15, 2021 are built with "new revised" full wall thickness axle tubes...the exact same 'new' tubes used on the 6.7L trucks.....then problem resolved.
IF not, the 7.3L trucks built with inferior variable thick wall axle tubes will not be good, especially if the tube is thinner below the spring perch...one of the major stress areas. Will remind me of the variable thickness of frames used on F150 trucks starting in 2015.
The following is
Off Topic but interesting nonetheless.
Yeah, different frame thickness on 2015+ F150 trucks depending upon build specifications. The F150 3.5L tow equipped and XL, XLT with certain payload option got a thicker frame, as did the Raptor. No 5.0L engine trucks were built with the thicker frames. Plus, the 5.0L trucks got the Super 8.8 rear axle assembly and
not the heavy duty 9.75 rear axle assembly.
A few years ago, I was thinking about buying a F150 with 5.0L adding a supercharger and having Paxpower / RaptorV8.com install OEM Raptor suspension or the improved higher quality Icon "Raptor style" suspension. Ben told me he can get the parts for either the OEM or Icon (normally $11,000+) for $7000 - $7500. I simply thought it would be cool to have a somewhat standard looking F150 (with Bushwacker fender flares / without Raptor body parts - VERY expensive - see PaxPower - Raptor V8.com for all the options) that could run circles around an OEM Raptor on pavement and off-road. I was up for pursuing the build, even adding the wider 9.75 rear axle assembly...but axed the whole idea after researching and reading about the different frames.
PaxPower specializes in high-performance trucks from Ford, GM, RAM, Toyota, and more. We convert modern trucks into dream machines!
www.paxpower.com
Proven off-road upgrades for Ford F150 trucks by PaxPower. We custom build your Ford F150 to be the most unique on the road. We supercharge and tune F150 trucks.
www.paxpower.com
The Supercharged F150 Alpha is a luxury hybrid-powered truck with Raptor suspension and 770 hp. The Alpha F150 is the ultimate performance truck build ever.
www.paxpower.com
