Audio upgrades
They replaced my subwoofer and amplifier, now it is loud but still not satisfied with the quality, (not very clear and still missing some bass) so going back next week (they said they can adjust something with computer) and if that will not be enough, will change speakers and anything else needed. But now it's way better.
Yes, the Banging the Olsen Twins Stereo - sucks.
I had everything redone in my truck except for the head unit. I have contacted my installer for the list and model numbers of what he installed so I can pass it on you all. Some of the guys that went to the Texas Hill run were able to hear it. FYI it's not cheap.
But it did sound really good! ?
B&O used to mean quality. Sorry to hear they let Ford compromise their standards. Luckily I've the US Navy to thank that I won't know the difference*, assuming that I ever get mine. :rolleyes:
*Sure was fun standing next to those guns though!
When your chest is compressed by the blast you know it was loud!
• ZEN A2B module from NAVTV
• JL AUDIO VX800/8i
• JL AUDIO VX600/1i
• JL AUDIO 10TW3-D4
• FOCAL FLAX 165FX
• FOCAL FLAX 165FC
Please contact Ron great guy and will always be there to help. He is located in NO CAL. Ron also did all my paint protection film, window tint, and Ceramic Windshield tinting.
[email protected]
[email protected]
[email protected]
• JL AUDIO VX800/8i
• JL AUDIO VX600/1i
• JL AUDIO 10TW3-D4
• FOCAL FLAX 165FX
• FOCAL FLAX 165FC
[email protected]
[email protected]
[email protected]
Thanks for sharing this. It's not on my short term list of mods, but at some point when I have the extra cash on hand I'd like to upgrade!
It's not as bad as I made it out to be. Sucks would be a little harsh. It's just average car audio - nothing to write home about. No pun intended.
Thanks for your service!
• JL AUDIO VX800/8i
• JL AUDIO VX600/1i
• JL AUDIO 10TW3-D4
• FOCAL FLAX 165FX
• FOCAL FLAX 165FC
[email protected]
[email protected]
[email protected]
With that JL sub, they must have done something different by way of an enclosure. Was it an MTI enclosure or something built in house?
I agree with all of you this b&o system is not at all impressive. I traded in my 18 ram with the alpine system for this tremor. Honestly that ram sound system was probably 5x better. It was incredibly crisp and POWERFUL (for a stock system). This b&o system is probably a third as crisp and a fifth as powerful as the rams alpine. Dont get me wrong I love my tremor and am very lucky to be able to own such a nice truck. But with everything in life there are pros and cons.
I just received the final piece of my new build because as others have mentioned the B&O sucks. Anyway, I have the zen a2b interface, with a Rockford fosgate 360.3 dsp, a 5 channel fosgate amp with s&b accoustics raw drivers for the front, a fox box with single soundqube 10 under the seat. Everything mounted on the back wall using amp rack from sound good stereo. So hoping with some time and patience that I can turn the tunes up and enjoy them again.
What size/impedance is the factory subwoofer? Anyone know?
I checked on my receipt and I got the following change: (if that helps anyone)
Audison SR 5.600
Audison APS 8 D
Nav-TV ZEN-A2B / DSP12A-A2B
Loud enough but still need some work on it.
I've been researching this extensively. The B&O does not match up to the price tag of the vehicle in my opinion. I have a consult pending with a local installer. They are very familiar with the B&O shortcomings and are familiar with the needed/requested upgrades that are being done. There is a replacement "system" (component package) out there that they use which they tell me addresses most peoples concerns. However, they also do custom installs based upon your specific taste. If and when I get there to check it out, I'll report back. Not sure when that will happen though. There is some additional information on this specific topic on other forums as it's not limited to just Tremors. Those with much more experience in quality audio (audiophiles), than me have been very helpful in suggestions.
If I understand correctly, if you have the B&O system, you can't just upgrade the sub like many have done on the base audio systems (many guys did it on F150s). Correct? The way I understand it, you must use the NAV TV unit (or similar) and delete the factory amp...so at a minimum, you are replacing the factory amp as well.
MANY moons ago I built some custom sub enclosures and did some light installs, but things are VERY different now and I'm just trying to wrap my head around what I can do and how deep of a plunge this will be. Point is, I'd like to start by simply building a new sub enclosure and upgrading the sub...but it looks like the minimum starting point is upgrading the amp for every speaker as well.
You can upgrade just the sub, or the sub and amp without removing the b&o amp. Just need a high quality hi level converter or an Amp with it built in such as audio control or kicker that come to mind. The nav tv unit is necessary when you do want to replace the the b&o amp with a multi channel amp or processor etc. like I am in the process of doing.
Thanks. I got the truck a month ago and have barely driven it, nor have I had the chance to really dig into the audio system too much yet...other than knowing long term I would like to make some upgrades...but not necessarily all at once, right now. I don't like buying things twice, but it definitely needs more low end for my taste...so maybe a line output converter (which is what I assume you're referring to), an amp and a better sub will be ok for now. Again, thanks.
Correct line output converter aka hi/low converter. And for the sub the stock sub box/enclosure if you want to call it that can be modified to fit a new 8 inch sub or there are some options to fit behind the seat or under the seat. Just depends on wants and goals really. I am building an amp rack for behind the seat and sacrificing under seat storage for a fox box with a single 10. New front drivers all wired up to a dsp and 2 Amps. A lot of work but will be worth it in the end.
Gotcha, just wanted to be sure about the LOC. Thanks.
Yeah, in my experience an 8" is a waste of time, so attempting to upgrade the factory enclosure isn't something I'd bother with myself. And the behind the seat stuff is challenging because anything I've seen requires seat relocation brackets to keep the sub from hitting the seat back with the seat is folded up...and I don't really have an interest in that.
I'm similarly looking to build a new enclosure that would replicate the under seat storage box, but half would be for a 10" sub (likely down firing) and the other half would be for storage (similar in total size to the OEM storage box, but would have a smaller storage area). MTI Acoustics makes them in that configuration (and they appear very nice), but they want $525 just for the box...and I've built enough of them before that it doesn't scare me. I've got a set of Boston Acoustics Pro Series 6.2 sitting a box in like new condition that I'd like put up front since I'm sure they're light years better than better than the front OEM speakers. My fear is that this is going to lead me down a rabbit hole and suddenly I've dropped $3k in upgrades for what started with a simple sub upgrade. LOL.
