I am wondering how many of you are using an ARB compressor or a Power Tank or fill up your tires after playing off-road. Thought about getting an ARB installed but moving part break, but then again the power tank needs to be hydrotested over time.
Can of ether and a lighterI have both, power tank is awesome until its empty, and I Gotta get my tank rectified. Hoping an air tank with the arb will allow blowing a tire back on the rim.
Have done that when I was a kid, now that I know it can go wrong it almost certainly will lolCan of ether and a lighter![]()
do they still sell starter fluid? gotta illegal in CA by nowHave done that when I was a kid, now that I know it can go wrong it almost certainly will lol
Out of curiosity, how is the PowerTank less maintenance than the onboard air system? What maintenance are you doing to your onboard air system?less matainance than a on board air system
Admittedly I've only ever had a compressor in a bag, but I've done nothing to it over multiple years with regards to maintenance.
Ahh gotcha. So I'm avoiding all of the maintenance issues by having a portable compressor as opposed to on-board.I had air lines both in the front grill and in the bumper by the rear license plate. Both lines developed air leaks & the valve in the tank to drain it was damaged somehow causing lots of heartburn
Was easy to clean the air filter for the compressor & that’s where the ease ended lol
Ahh gotcha. So I'm avoiding all of the maintenance issues by having a portable compressor as opposed to on-board.![]()
