ARB air compressor
idrivea2022tremor
Tremor Addict
Founding Member 📜
San Diego
2022 F250 Tremor 7.3, 2002 VW Golf, 1991 Avanti
All,
I have my ARB compressor installed in my truck from the group buy a while back. Just the other day I started my truck and it came on, like it does, to charge the tank. However, after it charged the tank it kept running. I turned off the upfitter switch and continued running. I finally pulled the fuse to turn it off.
I don't have a lot of experience with these, are there any common failure points I should investigate before I take this completely out of the truck? Has this happened to anyone else?
Thanks.
All,
Thanks.
Sounds like the relay is stuck in the on position, contacts closed. I assume this would be the internal relay on the compressor if you did a standard install. Most likely a warranty issue with ARB. It may be something fairly cheap to buy and get one locally for extra speed, but I would contact ARB just to get their advice.
I called the ARB rep and he basically suggested the exact same thing. He's telling me they see this quite a bit when people don't use the supplied switch.
I was telling him I often just leave the switch on and it starts compressing when/while my engine is cranking. Thinks the voltage drop/surge caused them to fail. Might change them with a time delay relay so they wait a minute or so after receiving power.
The other failure point could be the upfitter switch/relay. If it is wired to an ignition-hot switch a simple test would be to turn off the truck/open the door and see if the compressor keeps running. Lower likelihood than the ARB relay I would think...
It is wired to an ignition hot switch. It's also the same switch as my air horn, which is working correctly. I don't think I damaged the factory harness.
Air horn has a secondary relay that bypasses the factory horn when the upfitter is on.
Related question, does your air pressure leak down when the truck is off? If so, what type fittings did you use with your system, push locks or threaded pipe fittings? Curious as the system should hold air tight even when off for a day or two. If it is leaking down, if you correct this, it would not be calling for compressor on when you start your truck.
It leaks down after a few days. I use DOT approved push-to-connect fittings and DOT approved air brake hose. I know I have a leak somewhere but as it "drains" the tank after 3-4 ish days I haven't been bothered. I could probably optimize the routing a little and remove some of the curves in the hose.
This compressor/tank set up does more than just my horn. I have quick connect fittings at the front and rear as well as an air block to control the air bags. There are probably 40ish leak points in this system.
My system without a tank leaks down slightly too when the truck sits overnight, meaning, if I hit the upfitter switch it recharges almost instantly.
I attribute this to temperature difference as the truck sits overnight, the pressure stored in the lines will change, and therefore the sensor will see this lower pressure causing the compressor to briefly turn on again.
Same with mine...
Is this the Limitless relay/harness or did you wire it yourself?
Limitless. But probably should have wired it myself...
Although having the OEM connectors was quite nice.
I have that harness and the horn ready to go in, just haven't installed it yet. After receiving it I was debating just wiring the horn in to an upfitter. I will probably still tie it onto the factory horn with the Limitless kit but wanted to think it through a bit more first...
I guess I lucked into tight connections when I built mine - I lose pretty much zero pressure from my tank when it sits. I kick on the ARB upfitter manually when I’ve been using the air extensively, but it never needs refilling just from sitting. The tank fills to 150 psi when the compressor works, and the compressor won’t kick on again until the tank pressure drops below 135 psi. Not much point in having it in constant “on“ as far as I can tell.
And @Modman, I would humbly suggest leaving the air horn activation on just the upfitter, which is what I’ve done. My horn is a relatively standard 2 trumpet 150db horn, and frankly, it’s scared the bejeezus out of everyone I’ve used it on. My regular horn works great for run of the mill alerts, and the air horn only gets intermittent use when idiots demand it. My air horn is frankly just too loud for regular run of the mill traffic use.
Appreciate the recommendation @cntyguy . I am going with a bit different setup. Even though I have the ARB, I purchased a self contained twin-horn marine setup that isn't as loud as a tank fired horn. The specs say it is 125dB iirc (still an increase over OEM). My thought with the relay setup is that I could leave it switched as a safety measure if a would-be thief is planning to disable the factory horn. Of course that depends on where exactly they cut the wire... I have some ideas to help with that too, though, and will think through it more when I do the install.
