Anyone cut into their rear bumper to mount lights?
Pretty sure @Nick@ApolloOff-Road cut his BD lights into his rear bumper, it looks great
Yep! S2 Pros running our dual function harness. Used a drill and a metal Dremel blade and a file. Nerve wracking, but after a few beers your hands get steady :LOL:
full
I did mine with Baja lights and was able to use a hole saw for the light housing to fit through. Just because the outside is square, you don’t always have to make a square hole to mount. Depends on style/design. My thought was, if I screw it up I can get an aftermarket bumper.
That will work for the S1 lights, you only need a 2.5" hole saw. However, the S2s are rectangular so it's a little more work. I did the S1s with our bed step kit:
I did the 2” Vivids in my Ram bumper. It was easy enough with an angle grinder. I was really happy with them. I just did the BD S2 kit on the Ford. I don’t wheel much anymore but when I tear them off like I have with all my below bumper mounted lights I will do some flush mounts.
Like an idiot, I purchased the Nacho Nano lights to install at the back of the truck to use as additional back-up lighting before I got the truck. I had planned on just cutting into the rear bumper to mount them. But now that I have the truck, I see there is a bit of an angle to the bottom of the rear bumper and cutting into it seems so permanent.
Should I just suck it up and whip out the dremel or does anyone have an alternative to mount these little guys? I was hoping to find the hitch extensions but they all seem to be pre-cut for other lights.
I love the look of the lights in the bumper. But I’ve always used brackets under the bumper that bolt on in case I trade lights or trade trucks.
If you want to kick around possible ideas for a custom bracket, let me know!
Totally understand the hesitation because I felt the same way. I didn't want to make any permanent modifications to my truck so I designed and 3D printed my own reverse light brackets. That's actually what led me to make the hitch tube mount brackets I sell now.
I don't have a mount specifically for the Nacho Nanos but the 3D printing process makes it pretty easy to adapt my design for a custom housing or mount for virtually any lights. Happy to look into it if you want a solution that requires no cutting or drilling.
I mounted the lights over the weekend. I had a couple of friends over to help with wiring and stuff also for other items, so I decided to just set the lights around and see what worked best. I ended up mounting them on the inset part of the tow hitch. I can post a picture later tonight when I get a chance if anyone is interested. It worked out well, the lights are protected by the hitch unless I happen to hit a rock or something between the two ridges the lights are hiding in. The don't extend low enough to drag on a relatively flat surface.
I’ve not done it yet, but I’ll be cutting into my 1 month old rear bumper soon to flush mount a pair of lights I bought while waiting on the truck to arrive.
Wait, don’t cut!! I can make you a mount!!
Just got new pictures from a customer today for the rear bumper step. They came out great!
I have been looking for good measurements on the Nacho Nano, Morimotos, and Dioide Dynamics for anyone interested in contributing to expanding. Send me a PM.
Used a pair of these lights. Welded together some silly little brackets with some cheap angle braces from the scrap bin and bolted to the existing bumper shell bolts. Tweaked to get to shine where I wanted. Honestly the factory reverse lights (led) put out pretty good light already, but tied into upfitter switch is nice to be able to turn on when working behind.
Ingenuity!
View attachment 258464View attachment 258465View attachment 258466View attachment 258467
Looks great, I like how the light hugs the bumper.
