Another audio upgrade
Thank you for all the input. Was the vx700/5 enough power for your base. I know the vx1000/5 doubles your base channel from 300 to 600. I’ve narrowed everything down to your build and in between the 700 or 1000. Thanks again for all your input
A single JL 10 is fine with 300 watts into 2 ohms. I don’t see any need for more if using that sub. The 1000/5i will give a little more power for the mains (100 vs 75 W per channel), but that’s a minor gain. I made the trade off between 700 and 1000 and don’t regret my choice.
Perfect, thank you again
I want to do this so bad. But with the wife and kids and sports, I'll be lucky to get it done in three months. I need to start putting together a list of components.
i think the stock radio will work just find as is...got other things i can do with 4K.
I hope this is last question, is the nav tv necessary since I will have an amp w a dsp? I’m having a shop install and it’s amazing all the responses I’ve received about how to add an aftermarket amp. The nav tv unit appears to be the best option w my limited reasearch and personal knowledge of audio components. Just trying to trim some of the costs if I don’t need it, but guessing I actually do and I trust your information more than some of these shops trying to sell product . Thx
NAVTV is necessary if you have the B&O factory audio system. The B&O system send a digital audio signal from the head unit to the amp behind the seat. NAV-TV converts this to analog multi-channel or optical digital depending on what you want to use. Optical is 2-channel only so you lose the fader function in the head unit - I used RCA analog outputs of the NAV-TV to feed the amp.
If you don’t have the B&O system, then you don’t need the NAV-TV unit.
Nice! Did you look into replacing the head unit and if so does anyone know if you lose your variety of camera views? Thanks for any info anyone can provide on this.
Given the integration of the OEM head unit with so many functions, and the fact that it outputs multi-channel digital audio signals already, I didn't consider replacing it.
Man that is awesome and well executed. Thanks for doing a detailed write up especially since yours is pretty damn close to what I want to do.
I highly recommend it :)
Let me know if I can help you along the way.....
great thread right here. Answers alot of my questions. Thanks
