Anderson Power Plug installed
  • OP 🔹 OP 🔹 FT_Guest3342
  • Start date Start date
I just bought a new security feature......a garage....it only cost 212K....and came with a house and 2.5 acres included!!
I recently obtained a new security system in March. I sold my 35 acre hobby ranch in the Pikes Peak Region NE of Colorado Springs and moved to Wyoming...the Cowboy state......remote area...OTG! People are within driving distance, but have several friends as neighbors and wild game close by. Crime Rate here is Zilch! However, I am well prepared for any gnarly person who might on the slight chance accidently wonder this way. The new place comes with Aspen trees, various species of Pine (Lodgepole, Ponderosa, Spruce), Scrub Oak, etc., along with Mule Deer, Elk, Bears.....and some awesome scenery and views!!! The "Outdoor Playground" is open year a round here for various activities...BBQ's, hunting, fishing, paintball, target and clay pigeon shooting, white water rafting, skiing, and riding snowmobiles! The sun is out over 300 days a year here and very comfortable outside with low humidity.
U must be in another country for that price ?
nope......NC........30 min from fayetteville.....and its a beautiful house to boot!
Keep us posted on the Stainless Cable Armor
When Extreme Outfitters removed my tumbler they also ran a wire from the battery to a mount under the right fender well, so if I did ever lose the battery(unlikely with 2 batteries) all that is needed is a 12v power source hooked to it and it will provide enough amps that the key fob will unlock your doors, then pop the hood and do what's needed to get it started! Very simple.
I installed the R2X Heavy Duty jumper terminals today. The terminals are a lot beefier than I thought when ordering it. I installed it on the passenger side behind the bumper bracket. I used 2 awg wire to the battery. The Anderson plugs are a great idea as well but this will save me if my battery dies when I’m not home and don’t have the other end of the plug.
View attachment 24076View attachment 24077View attachment 24078
Does it matter which battery these getting hooked up to? Installing the Jimmy Jammers soon and want this as a backup in case the batteries are dead and truck won’t unlock.
It does not. See this diagram I made, along with the original post it’s from, for details on how the dual batteries are wired:
1639176793364-png.41024
If it’s reasonably easy to do so I would wire off of the passenger side battery since that’s where everything else is wired off of (fuse blocks) but with the way the batteries are wired it shouldn’t really matter.
Sounds like my kind of paradise
What site are you all ordering the Jimmie jammers on? I found them on Amazon but was hoping to find them a little cheaper. Also, I think I will go with a jumper system like the link below. This way if my battery dies when not at home I could have any random person jump my battery with regular cables. I don’t want to have to keep up with or hide the other end of the Anderson plug. I can also use a heavier gauge wire. It’s also made in America.
Thanks for posting this way back. Used the same item, super easy install. The front license plate bracket pretty much completely covers it up.
Thanks for posting this way back. Used the same item, super easy install. The front license plate bracket pretty much completely covers it up.View attachment 52123
@Panther88 here is a pic of the battery for the connections. Just kept the lengths equal and wrapped in a loom for extra protection.
So, I've always kinda wondered, all you guys hooking remote plugs or clamp points up to your batteries...
If you're the good battery, you're hooked up both to Positive and Negative terminals so you can jump another car.
If you're the dead battery, you want to hook up to Positive and Ground (block or frame).
Which way are you guys connecting these remote points?
I was actually going to run two different lines w Anderson plugs, one for each scenario (jumping/jumped), or a single line w/a switch on the ground. I just haven't heard anyone differentiate when talking about doing this kind of mod.
Much of the engine block grounding is a safety thing. A discharged battery can be producing H(hydrogen), and possibly H2S (hydrogen sulfide if battery is damaged) and the spark from connecting the negative can ignite the gasses causing the battery to explode in your face. Moving the ground away from the battery to the engine block for the last hookup puts the spark away from a possible heavy gassing battery. I personally would not bother making 2 connections for each case since the sparking will be away from the battery if mounting in similar locations as in this thread.
Makes total sense. The procedure is so engrained that I never considered the why when questioning how it to wire it up.
