Analyze my oil
Gotcha. I probably an old virgin sample. The formula has probably changed though. It would be interesting to compare the two.
One option is to buy a 6 month PC membership for $10. That’s about $0.66 added to each quart for a diesel oil change.
I might do it for science. I am due for an OC though and already sitting on 2gallons of Triax, so either I buy another 2 gallons of that or try something else. Again, I am just nerdy and like science the Max Duty though is almost double the price as the triax so is it worth it ? probably not I could change the triax at every 5k miles and probably come out just the same.
Oh, I’m a data nut too. I get it.
Here is my take on the Amsoil line (if you care 🤣). I have used it for years and had a great relationship with the nerds over there back when they were a sponsor.
Sig Series is what most folks compare to other oils. That’s where it gets the “OMG it’s so expensive and doesn’t blah blah”. SS is not intended to be used for standard or short OCIs. It’s definitely not economical for that. If you aren’t going to run a bypass filter and shoot for 20k OCIs then it’s just a feel good that you spent the money.
The 100% Synthetic is what most people “should” run if only going for the manufacturer OCI recommendation. Definitely more economical when not extending your changes.
To make matters interesting, they just released a middle child line. The “Freedom Line” oils. Price point is between the other two. I’m disappointed I did not see it when I did my last oil change a week ago. I would have tried it out. Just for, you know, data.
OK, I decided to go ahead and use the AMSOIL oil analysis at my most recent oil change and service (95K miles). I got the oil analysis results back and I think i understand about half of it. I am not an engine data nerd by any stretch of the imagination and do not fully understand the numbers on the analysis. Anyone want to provide some insight?
OK, I decided to go ahead and use the AMSOIL oil analysis at my most recent oil change and service (95K miles). I got the oil analysis results back and I think i understand about half of it. I am not an engine data nerd by any stretch of the imagination and do not fully understand the numbers on the analysis. Anyone want to provide some insight?View attachment 255860View attachment 255861
High iron and aluminum… that’s interesting. What’s the miles and idle hours on the oil? I couldn’t find the miles on the report.
  • Like
Reactions: JDP
Total miles 95K. Changed every 5K with minimal idle hours. It’s a 7.3 and I know some of the diesel owners tend to idle a little more.
