Aftermarket Wheel / Tire Help
MaximumSVT
WI
MODS: Please move to Tremor Talk 23-26. Accidentally posted here.
Looking to upgrade to a set of Fuel wheels and new tires on my stock 2026 F350 Tremor with the 6.7. Wheel size will be 20x10 -18 offset. Initial thought is to go with a 35x12.5" tire. I do not want to modify the suspension at this time.
Will this combo rub at all? Also considering a 37x12.5" if that can be installed without issue.
I'm a wheel newb so any and all input is appreciated.
Pictures of forum member builds welcome.
Can't speak to the 20x10 -18 setup exactly, but here's one data point from a 2026 F-350 Tremor: I run 35x12.50R18 Falken Wildpeak AT4Ws on 18" Foundation 395HD wheels at +19mm, and nothing rubs. Mine isn't bone stock, though. It has BDS 1-2" leveling coils, which I put in for the ride more than the height, and the height change is minimal. If I bought wheels again I'd go 0mm offset instead of +19.
Off topic however curious what ride difference you noticed with the BDS coils over OEM? One other member did the same thing and reported a slight improvement in small bump compliance. Seems a good option for those wishing to level their rides without significant geometry changes that would require new track bar and brake lines.
The ride was the main reason I put the BDS 1-2" coils in, and the difference over stock was very noticeable. I never measured hub-to-fender; the height change is minimal. I also added a Carli track bar and NX2s with that setup, so I can't isolate the coils alone, but the ride improvement is what I noticed most. After install I've had no issues with alignment, adaptive steering, or adaptive cruise. If you go the track bar route, retorque it after a few hundred miles.
