Aftermarket subwoofer box - seat move?
Sorry, I really didn't take that many pics. Here's one of the enclosure the day I received it from MTI and 2 pics of it mounted and where I ended up putting my amp and another pic of some of the wiring.
I was torn between stealth/behind seat and under seat. I ended up going under seat but I still wonder if I shouldn’t have just done something like you.
Damn these are awesome, I too have been debating the MTI Acoustic setup for behind the seat. We have three dogs and a 6yo (6yo sits behind the passenger and the 3 dogs [all rescue pocket pits or pit mixes] are on a kid mattress on the floor with the seat up).
I decided to go with a JL Stealth box which has two 12TW3, it only requires that the under seat storage be removed, but beyond that.. with the seats nothing needs to be moved nor lifted.
I am running the VX1000/5i w. NAV A2B with optical input
Good choice. I bought that Stealth box too.
MTI also warns of playing the music with the seat up. I never drive around with the seat up, so it’s not an issue for me. But if you do have the seat up a lot, something to think about
The seat up, is that the bottom seat folder up or the seat back in the up position? Assuming the bottom in the up position (like for storage access) as it seems to move the back rest rearward a bit.
Yes. when it moves back you risk the sub hitting the back of the seat as it moves in and out.
Folding the bottom portion up to access storage. That’s when you don’t play music
Where is everyone running the power wire through the firewall?
Thanks @Vecman for the recommendation on MTI. Just had a great conversation with them and ordered an enclosure and amp rack. I'll post some pictures when I get everything installed.
Going with this box w a JL 13.5 and the amp rack that sits on the shelf, 1/2 under the seat. They said that for the 13.5 JL; the seat does not need to be moved forward or up, due to the short throw of that sub. I'm sure it won't hit as well as a pair of good 12's but this as much cubic volume as the box has, it should still produce some decent bass.
View attachment 108309View attachment 108310
I just ordered this exact setup from them 2 days ago. I'll be picking the box up in around 2 weeks or so. I've had the 13.5 installed in my '15 for the last 5ish years. This box is going to be a little bigger though, so I'm curious what effect that will have on the sound. I'm going to swap out all 4 door speakers for the same Focal's that I had in my last truck, but I'm going to run them off of the B&O amp for now. The previous Sony amp was enough for them for my ears. If it's not, I'll be adding another amp and a ZEN-TV module. I'm planning on hooking the new sub and amp up through my LC2i. I was going to buy the $80 wiring harness from plugandplay as to avoid splicing any wires. I've already bought the factory door speaker wiring harnesses. I'm still on the hunt for the factory tweeter harness. Do you have any pics of the setup? After nearly a year, do you have any regrets?
Am I correct to assume none of these solutions will work with the Pro Power inverter right there?
I was told yesterday that the amps could be relocated to under the driver or passenger seat. The amp rack they sold me goes in the spot behind the storage box, under the seat where that Pro Power inverter is installed.
