Aftermarket LED Headlights
Oem ford led is $1700, dealer cost is $1k per light. May need addition wiring harness.
Thumbs up for the info, thank you. Thumbs down on the price lol
Here are the new morimoto headlights I posted about earlier. I think they look amazing and will look even better on a lariat sport. I suspect the price will be around $1,500, if you want them be sure to pre order them as their stuff goes quick. They should be available next month.View attachment 6911View attachment 6912View attachment 6913View attachment 6915
Lariat Sport LED are smoked which is different than every other LED SD option. Will these come as smoked too? I really like the look of the oem LED and would not switch them out. However I don't have LED haha.
Yes, looked in to it before ordering since was on the fence between XLT and Lariat. It is rather expensive to add factory LED after the fact but can be done, not sure on availability on the parts though. I ultimately opted to order a Lariat with the sport package so got the factory LED but would have got the F150 LED kit or something similar had I gone with the XLT due to the cost of the OEM parts.
The Tremor I am working on is still in transit but it has the lariat sport package. So it does have the OEM LED light? The window sticker does not clearly state LED headlights.
jeff
jeff
Yes the sport gets a blacked out version of LED headlights. You also get the LED fogs and tail lights.
I'm sorry if I'm asking anyone to repeat theirself or if I'm beating a dead horse but I saw this:
I am in the process of ordering a 2021 F-350 Lariat Tremor with the Lariat Black Package, Ultimate package etc. and there is no mention of LED tail lights in any of the descriptions.
Is it possible something changed with the packages between years or there may be some other bell or whistle I need to add to be sure of getting LEDs front and rear.
The dealer said "it's probably part of the package but just not worded well"
Is there any doubt about the LEDs for 21'?
Had the same question on my 2021 and was told by dealer it is all included in the LED package.
It was not called out specifically in the 2020 order guide either and has the same description as the 21 black appearance package. My 20 Spot value package definitely has the Led tails and would be surprised if the 21 Black Appearance Package is not LED, but cannot say ?
Unfortunately my 21 king ranch didn't have the black appearance package option for some reason. I will be ordering the black package quad beam led headlights to swap out right away. I will be selling the stock quad beam headlights. I still need to find out what the oem black ones cost. I will post once I find out.
The Black appearance package is only available for the Lariat. the lights are 1600 a piece rumor is its 1k dealer cost. There is likely a shortage of them
I just emailed my sales guy to see perhaps could the Quad Beam LED headlights/taillights be special ordered on my 2021 XLT 6.7 Tremor ...I placed the order yesterday in Minnesota. He said he would check and get back to me and also mentioned they may be able to add the dealer cost to my bottom line and do the conversion at the dealership when the truck arrives. He said it requires the Quad beam LED assembly pair, the module as well as re-programming the computer
It will likely will require an adapter harness. That’s something the dealer won’t be able to do. Halogen to Oem LED is not plug and play.
Morimoto says their XB led headlights will be available in the next couple of months
This was posted on the Tremor Facebook group yesterday:
"A little sneak peak of the latest and greatest from the lighting wizards at @morimotohid
Dang....., those would sure look sharp on the XLT i got ordered.
those look awesome, but they will be pricey. I will probably end up doing the Creed LED light kit for headlights/fogs/rear reverse and tag lights
Honestly I will probably end up getting the Morimoto XB Hybrids. They should be about $900. Yes that is very expensive for headlights.
But less than the XBs at probably $1800 and WAY less than the $10K that a Lariat Ultimate would have cost over the price of my XLT
My exact thoughts! And its why I went xlt...one I like cloth seats, secondly it was not worth the extra 6k plus extra to go to lariat for my build to just have oem led headlights.
You don’t get OEM LEDS with just lariat you get halogen same as the XLT, if you want LED you then have to add the lariat ultimate or blackout package on top of it for another $4k on top of the lariat price
Yep, mine swapped out easily by just removing the airbox.
Yup, that’s really only necessary on the Diesel engine because there is practically no room.
what are the bulbs you got, i got mine from f150LED paid 400 and they do not fit my housing.
I bought (H13) size and they fit fine in my truck. Also 3157 switchback light for the turn signal. Stays white and turns orange when you turn signal on
i got mine from F150 LEDs also, and the fit my truck just fine. What doesn’t fit, the socket or the depth? Did you talk to their customer service? Mine were the Mark V factory replacements. This one.....
the TFL truck is the 7.3 Gas, not the Diesel. And it’s a 2020 model which has the same grill as the TREMOR. I have verified that because I swapped out my factory grill to one from an XL and it went on with no problem. But there is no reason to take out the headlight housing on a gas truck. There is Plenty of room to do a bulb swap.
I quoted everyone to see, if anyone has done the 7.3 led bulb swap without pulling the headlamps?
It looks tight the get my hand in to the bottom bulb on the drivers side. Can you swap them out and get the connections without pulling the lights?
My bulbs showed up today.
