Advice Needed on Truck Topper Power
BDTremor
Tremor Fanatic
Denver, CO
USAF
2026 F350 Platinum Tremor 6.7L HO
2014 Jeep Grand Cherokee Summit
I have a 22 F350 with an ARE topper. I selected the 12V power strip as part of my setup so I could have a power port in the bed for small accessories. This power strip connects directly to the topper power and does not have an on/off switch. The only way to disconnect it currently is to pull the connection pin which is easy to do. There is nothing connected that draws power except for a few small lights (5) on the unit itself. As far a driving habits, I usually go several days up to a week between drives. What are your thoughts on keeping it connected and pulling a small amount of power continuously for my use case? I've considered adding an inline power switch as an option.
Wonder what gauge they wired that with. Doesn't really appear to be a high quality unit either, I'd replace it with a similar blue sea panel with power switch built in, or add an inline switch. Doubt those lights would ever kill your battery though sitting a week.
I personally would connect a switch of some kind. I like to always have control to turn it off in a flash if necessary. Also, a built-in circuit breaker is better.
The LEDs will draw low power and may not impact your battery over time; however, they already show that your battery is low based on the "low" led glowing red. I know these trucks are very finicky with battery levels and if you do decide to leave it on at all times, consider a battery maintainer you can leave plugged in at all times while not in use.
One more consideration, any 12V socket with plastic around the edges like that aren't really designed to handle any amount of high current. So, depending on what you intend to run, there are better options available. I like all metal sockets. If you must have three sockets, here's an example.
Also, as @hour points out, Blue Sea is a higher quality socket, but I didn't see any with three sockets as such. There are many configurations.
@Canyon Trekker I wouldn't put much/any stock in that voltage light being correct for two reasons - one, it looks like a $10 unit from Aliexpress... and two, OP mentioned it's connected to the topper power which was connected to where? Probably 25ft of 18 gauge wire, and spliced using those quick connect solderless splices to get to the sockets. The leds themselves are probably causing voltage sag :ROFLMAO:
The unit you posted looks nice for the switch but 3 is just uncomfortable until wiring is figured out. I'm imagining this would be OK for charging phones but at that point I'd rather get a single dumb socket with dust cover, no lights, and a cig socket->multi USB output brick.
@oUyHviB433YtNiLbn what are you trying to power and what are the details of the wiring if you happen to know or be able to see how it connects to the topper's power
I have to agree on the unit being subject to inaccuracy, and also agree that three sockets with a total of 16A capacity, is even questionable. It was just a suggestion to replace the one he had. I think LEDs on a socket are ridiculous anyhow. Gimmicks.
If there's no need for three sockets, the brick you show a picture of is ideal if USB is the goal. Typically, these days, people just use a 12V to USB adapter anyway. The above item will charge virtually any device with QC 30 and USB-C sockets, but it still has to plug into a 12V socket.
I would be running a 12-gauge wire to a single socket for that distance. I wired my center dash sockets with three different taps for 12V hot always, ignition only, and one upfitter drive.) All single dummy stainless-steel sockets and use adapters as necessary. One socket is for the Garmin Camera/GPS which uses the 12V socket.
I have the same setup and I do believe the lights go out when the top is closed. I haven't had to use mine yet so I can't confirm that they remained powered or not when the truck is off. Like you I added it to the order when I bought it but I haven't had the need to use it yet. For me the use case would be a way to charge my phone when doing an overnight in the back or running a cooler when on long trips. I am concerned about the power handling capabilities so I will have to do some checking before connecting a high current draw device to it.
I used to power a Whynter 12v compressor fridge off of a deep cycle lead acid battery. I kept tripping the low voltage cutoff on the fridge unless I set it to the (kill my battery) setting due to voltage sag when the compressor was running, a whopping 5 amps @ 12vdc. I used the stock 5ft DC cord and lopped the cig part off, added ring terminals, and connected directly to the battery.
I wouldn't be surprised if your fridge instantly cuts off when the compressor kicks in. Double damned by the meh qualities of cig plugs and the likely puny wire run. Consider 8 gauge fine strand (easy to work with) pure copper welding wire run from the battery to the bed for fridge and more, or maybe a "solar generator" that you charge from the inside of the truck, probably not these sockets either 😅 lithium is king when it comes to minimal voltage sag at the battery and you might get away with keeping the doodie cig plug that fridges ship with.
That's a great idea. I have the Massimo fridge and their version of the Jackery type lithium battery pack. Run the fridge off the battery and charge the battery form the 12v receptacle. I'll be dragging the battery along with me anyway for these trips.
I'll give it a try!
I'll give it a try!
I wonder if your power pack has the ability to adjust charge current - the two peewee Ecoflow River 2 units that I use in UPS mode to keep my home network running let me specify both AC charge (100-360w) and DC charge current (4 amps, 6 amps, 8 amps).
If your fridge draws 6 amps when the compressor is running at max and would cause severe voltage sag on your topper's wiring - to the point of causing low voltage cutoff or just being unkind to the compressor, you could theoretically use the power pack as a buffer at a lower charge rate (provided you have the option in the settings).
Using my ecoflow river 2 as an example: fridge pulls 6 amps of power when the compressor is running which is say 50% of the time -> Ecoflow charges at 4 amps 100% of the time/whatever needed to maintain full state of charge -> fridge will keep running and the power pack will see light charge/discharge, not severely degrading its life.
Of course none of this is the most efficient way, losses going from truck battery -> boosting voltage to charge power pack -> bucking voltage to 12v for the socket powering the fridge, but it seems like an OK solution in a pinch. I did try to research various Massimo power stations and it seems like they're 10.8v batteries meaning they're boosting to give you 12v fridge power. It also suggests that they're using the go-boom kind of lithium batteries, that I'd be wary of having in the back of a 130*F camper shell potentially bouncing around. Couldn't find details on controlling charge current or min DC input to charge. Anyway I wouldn't plug that in to your topper's cig plugs unless you can figure out what kind of current it's going to pull. If it's potentially greater than the fridge, not really any point. Sorry for hijacking your thread OP 😅 may give you some ideas too though.
