Advice installing Road Shock 4 LED ditch lights - Need daytime running light power
The white wire is the high output of the light so, you would hook the white wire to the upfitter, black to ground, and terminate the remaining wires so they won't short out to anything. If you want the amber light as well, hook the yellow wire to any + ignition source. It will be on at all times with the truck running. If you want the amber to come on with the DRL, consider the accessory noted by @Tremor32 .
As for ditch lights, use any of the upfitters to run them so long as they do not draw more than 25A. (Which they won't.)
The winch. Now this presents a lot more questions. The winch you speak of comes with a disconnect switch. It is mechanical. The power leads will be directly connected to the batteries. If you want to energize the winch with an upfitter, you need a very heavy contactor type relay which is additional accessory. So, the question would be, why do you want to run it from an upfitter? The Bad Lands winch has a remote control that unplugs and basically disables it. I highly recommend using the manufacturers guide to install and hook up.
If it really is your intention to run it with the upfitter, you would replace the mechanical switch with the relay. Then I would use upfitter 5 or 6 and set my under-hood control so 5 and 6 were always hot. This way, you can run the winch without turning on the truck. But warning, it won't run very long with the truck not running.
thanks for all the great info. In regards to the winch, this is my first winch to own so I am not too familiar. I haven't even looked into the wiring or setup of it. I had just bought it when they were having that great deal on them. I was under the assumption I would use an upfitter to turn power to it on, and then would use the remote from them for actual winch power. Whatever the best, straight forward setup would be.
The upfitter absolutely cannot power a winch. I would just connect it like the manufacturer installation states, no further switches necessary.
I read the plan but I think you will need to settle a few things or end up with a bit of wiring to battle with.
1) Using upfitters is as easy as you could ask for. Simple version : Feed power wire, run the ground. DONE.
2) Using the lights as "daytime running" : Requires them to run off a 12V source that's KEY ON power. Not hard.
3) Using them as "high beam spot" : Seems like you would need to tap off the OE harness, then have a stand-alone harness to feed your ditch lights. Which "might" need to have a tap to run the 12V KEY ON power as well.
Here's my suggestion if I understand the lights are dual-function daytime low power (hence a back light so to speak) and full power high beam : Run the upfitter to the full power high beam side. Use the up-fitter when you want, but you got to turn it off. Then feed the daytime low power side with a 12V KEY ON source.
Circling back, This is what I'm going to do.
use the snowplow plug if you want the backlights to come on with the park lights
How do I do this?
How do I do this?
There's a harness you can buy from a few vendors. I'll have to find my vendor link.
EDIT :
Here's the vendor I used. I got him to add-on a few other leads to make better use of all the other things on the snowplow connector on the truck. I emailed him, spoke to him on the phone, and he got the connector done. So I got the connector with High Beam trigger, added on a Left and Right Turn signal, and a Parking Lamp wire.
Highly recommend him or at least whatever company does the same sort of connector mods.
EDIT :
I ended up emailing him and bought this kit he recommended for me
This and a few other similar adapters only get you running light signal. There is an adapter that gets you turning signals, more expensive, but totally worth it, i drive three separate pod units from it.
Yes I saw that but am not planning on much other lighting. If I do down the road I can switch. Really trying to keep everything on a budget for this truck. I do like the turn signal and high beam options though.
Technically these adapters have all these signals already, one just needs to identify them, tap into the right wire and extend it. That’s what Randy Vanepps at customauto did for @HeavyAssault.
What 14-3 wire do y'all recommend for wiring lights or is all pretty much the same?
Kinda depends on the lights you want to run. If you're running a single set of lights or a lightbar, use 14-2 tinned copper. Most lights come with a harness, again, depending on which ones you get. In some cases, you may even only need 16 gauge. 14-3 usually has a green ground wire with a white and black wire. You only need the two wires for lights unless you are using a relay setup.
Wouldn’t I need the 3rd wire to run the amber backlight? I’m installing Nacho nanos and I believe it shows a ground wire then one for the actual light and one for the amber backlight light. My plan is to run the amber back lights to ignition power so they are on when the truck is on and the white light to the upfitter switches.
Ah... Yes. In that case, you would run a three-wire setup. I didn't know which lights you were hooking up. Again, depending on the lights you get, the wiring can have multiple taps for high, low, and amber. You can also check with the manufacturer for a harness already made up. The amber light will draw very little current, so a 14-gauge wire is not necessary. I would still use a tinned copper (or manufacture supplied wire) to hold up under most conditions. Copper clad wire, though less expensive, is not good for automotive wiring.
That harbor freight harness is unnecessary complicated. I gutted mine trying to understand how to tap into it. Ask if you really need the low, i didnt and removed a ton of complexity in wiring it up to up-fitters with high only.
You can conceivably wire it with high or low "only" where you control it on or off by an upfitter switch and still have the driving running light operate the amber backlight.
Sorry for the long delay. I'm just now getting to the actual install. Apologies also for my not understanding initially what you guys meant. And also thank you for your help and patience.
I now understand I want to omit the 3 way switch in the harness wiring kit. I believe I want to keep the Relay, or no? I am going to run only High beam to upfitter, and the DRL backlight to 12v daytime with the adapter I bought from Custom Auto Works.
I understand pin 4(white) at light connecters is my high beam, I dont understand what to do if I'm keeping or omiting the relay.
light diagram
wiring harness diagram
If using the OEM up-fitter you do not need any additional relays in the wiring.
If using the CustomAutoWorks connection your LED pod backlight should be on with the headlights. Then when you power with the OEM up-fitter the backlight goes out, to use the primary LED for light.
Can you post a pic of the connector at the light and any additional length of the wiring harness you will be using??
I got it figured out. Once I dug into the harness, disconnected relay, traced wires from switch. I realized I only need Yellow for the backlight going to the adapter harness from Customer Auto Works, black to go to ground, and White for high beam power to tap in to the upfitter switch. Just need to figure best way to run ground to battery or a ground in engine bay.
Ground at the most convenient spot. Either chassis or battery direct will work fine.
Last thing I need help with, I got the spot/flood combo, I am not planning on running any more front lights on bumper or anything, how should I aim them?
You can use your garage door or any big wall. Park about 20-50' away. Turn on your headlights, see where the OE pattern hits. Maybe aim the spot just over the OE pattern. Then it's just drive around a variety of roads/areas. If you need to make any more adjustments you will have a good idea what you like in the new pattern. :cool::cool: :coffee: :coffee: 🇺🇲 🇺🇲 🇺🇲 🇺🇲
What pod lights/ditch lights are you using and what mount, I love the look of yours
