Adding Oil Pressure sensor
My solution
Went down a rabbit hole and ended up landing on our trucks not having oil pressure readouts.
Thoughts on adding this adapter plate to provide ports for adding a digital oil pressure sensor? I know itll lower the oil filter. Not concerned with that at the moment/dont want people getting stuck on that piece.
Does anyone know of a quality oil sensor that would provide accurate digital pressure readings capable of handling motor oil/heat? We have numbers/data for nearly every other fluid in our 7.3L trucks. Feel like this could add some value, especially for the guys who idle a bit. Granted, i'm not sure anyone knows (maybe someone does) what the psi should be for 'good' lubrication. Measuring something when you dont know what it should be isnt that helpful (ill admit).
Just looking for objective and constructive thoughts/opinions.
I
have that same adapter, to add Banks sensor through my Banks Idash. Did my oil change today, forgot thread sealant and forgot to order my sensor kit. Next time though. The adapter is high quality but I think a relocation adapter is best, I will likely just do Amsoil Bypass filter kit/relocation. Had it on my 23 diesel, should have taken my kit off. Will update when I figure out the right parts.
