Confirmed i have a lead acid specific converter and would also need to replace this as well. At least the MPPT and inverter can remain the same thoughYour sine wave inverter won't care. It's just converts to a 120v output.
I was referring to the converter in your camper.
It will try to charge the batteries in the camper when you are connected to shore power.
It should have a setting/switch/jumper to tell it Lipo.
The manual would be a good place to start or google if you can find a model # on it.
I am learning so many new things! Thank youYou don't have to switch to a lithium compatible converter right away, or ever. The factory converter for lead acid will still charge the lithium batteries but not top them off. I ran my setup this way for several years because my solar always topped off my batteries for me. If my factory converter didn't fail, I would still be using the same setup.
Also, when before putting additional solar panels up, make sure your wire gauge is large enough for the additional amperage.
How has this cap been for you regarding being weatherproof? I see these all over amazon but none of them have any kind of silicon or rubber seal to keep out water. Is that not really a concern? I was looking at this one for in the bed (for the fifth wheel) as it seemed a little more waterproof:A mounting panel gives a nice finished look: https://a.co/d/blKjwun
Regarding batteries, I would advise researching quality. Don’t just shop price as there are unreliable knock-offs out there. Also there are features you want in your batteries like Bluetooth connectivity and built in heaters with internal control. Some even have battery management systems built in that protect from damage due to operator error.
That's a lot of battery. But too much is just about right in this case.This will net me about the same amp hours as my current lead acid setup (2 batteries @ 225 ah) but roughly double the capacity seeing as they are LiPo. The converter is to swap out my old one that is lead acid charging only. A 300W solar panel will also supplement some of the charging as well. I know i probably wont have enough solar for this much battery but i can upgrade that later. Here are some of the last questions i am trying to figure out:
When the converter is charging, it is charging. With Lipo mode, it should output a constant voltage, that you can set. But it's up to the battery BMS to control the amount of charging of the battery and go into float/trickle mode when the battery is at 100%. SOME batteries can be set to limit the amount of charge, but not the cheaper ones. And I doubt those ones have that feature.-Does the converter charge the lipo to 100% whenever it is plugged in to shore power? Can i limit that to a lower number using the bluetooth app on the batteries? Or is that a setting on the converter itself?
My plan charging plan would be - charge to 100% during camping season. Use whatever during camping, but in general try to keep it above 30%. The capacity during use will vary a lot, not worth worrying about. Then for winter storage/long term, drain to 80% and store. Then charge to 100% at the start of next season. Lipo will last 'slightly' longer if kept between 30-80%. It's not something to worry about. Many people use more than that. If it gets low, it won't kill the battery the same way it can with lead acid.-What SHOULD i charge the batteries to? 100% most of the time and then discharge it to like 50% prior to storing? Does the converter just take care of most of this for me? Would i just do some kind of bulk charge prior to a road trip where i need my fridge etc to be running off the inverter for as long as possible?
Hard to answer without knowing exactly what you have. But in general, if the charger is set to Lipo mode and the voltage is set correct for the battery, then it's just a matter of bolting the batteries in.-Assuming i swap out the new converter to the old one, can i simply just replace all the terminals on the two batteries i have now to these two new batteries and call it a day?
This is a very interesting question. Of the top of my head I would have said you'd be fine with 1 battery. But according to google the Onan recommends requires 350amp min to start the 5500.-I have an Onan 5500 generator. The reason i am doing two batteries instead of one larger one is to get the BMS amperage higher with two. My understanding is that 2 200ah batteries with 200A BMS each will have 400A of total BMS, in effect more "starting" power for the generator when i need to use it. Any single 400ah lipo battery i can find that may be slightly cheaper usually has a max of 250A BMS and im concerned that wouldnt be enough to start the generator?
You're asking all the right questions.Thanks in advance for any help you guys can offer. Trying to go into this considering all the important things. Im researching everything i can but its a lot to take in!
EXTREMELY helpful! Thank you. This video has me considering if i want to do just one battery but i still think two is a safer bet at the end of the day. Was reading the comments from the video you sent - one guy said there may have been up to a 250A draw that the app didnt reflect because it happened so fast. I could see this being true and helps me lean more towards the 2 batteries still.That's a lot of battery. But too much is just about right in this case.
I'll take a stab at some of the other questions, but you are getting into more product specific question - worth double checking with the manufacturer.
That seems high to me. And then I found this:
So I guess my answer is - 2 couldn't hurt, but 1 might work just fine too. Depends how well your 5500 starts and how cold it is when you camp.
This could certainly be true. Not sure how fast the app updates.EXTREMELY helpful! Thank you. This video has me considering if i want to do just one battery but i still think two is a safer bet at the end of the day. Was reading the comments from the video you sent - one guy said there may have been up to a 250A draw that the app didnt reflect because it happened so fast. I could see this being true and helps me lean more towards the 2 batteries still.
Secondly - check this out:
Should we be worried about having the 7 pin charger still hooked up when we switch to LiPo? This seems crazy to me (especially with our trucks alternators) but it has me worried now.
Again, much appreciated. All of this being said, im wondering if this is the route i go for a similar price and 100ah less:This could certainly be true. Not sure how fast the app updates.
But even in that case it's a surge. That wouldn't trip the BMS into cutting off. Most BMS will allow a higher surge. There cutoff rating is more for continues current and won't trip unless the current is above the rating for a few seconds.
This is assuming that all battery manufactures do their ratings the same way. And they don't because there really isn't any 1 standard. Not all batteries are created equal. This is part of the reason getting a somewhat reputable name battery is a good idea.
Yes, I've see that type of comment before. I'm fairly sure it's mostly fear and ignorance. 7 pin connector wires are very small. The wire itself will limit the current to much less than the Alt is putting out. If you somehow did draw a huge amount of current, the wires would melt long before the Alt got damaged. And nobody is complaining about melted wires.
In addition, that wire is not directly connected to the alt or battery. At least not in any more modern vehicle. So the current will be limited by the vehicle anyway, regardless of the battery type. 7-pin supplies very low current, to the point that it's almost useless. That's why people install dc-dc. My guess is that someone somewhere did there own wiring job and connected things directly and managed to fubar things up and that's how this rumor got started.
Fords in particular, the power pin turns gets turned off by the truck. It doesn't always have power, so it really makes no difference in that case. If it was a Dodge, then it is best to disconnect the power pin. But that is because Dodge has it as a constant power and it will eventually drain the trucks battery if parked and left connected to the trailer.
I believe this is a somewhat more reputable brand, and gains the heating function.
I have this one:How has this cap been for you regarding being weatherproof? I see these all over amazon but none of them have any kind of silicon or rubber seal to keep out water. Is that not really a concern? I was looking at this one for in the bed (for the fifth wheel) as it seemed a little more waterproof:
