AAWireless for wireless android auto on sync 3
Can confirm, works amazing.
I like the idea of not always charging my phone while in the truck. Trucks 9 months old with 19,000 miles so my phone is always plugged in.
Has the price come down yet?
No. It's actually going up due to chip shortage if you haven't already ordered.
Just got an email this morning for an update and they are having to redesign the board to support multiple wifi modules which is making it more expensive.
Well just got mine. Plugged it in, followed the instructions, and it worked right away.
Impressed with the app. Far more polished than I would think for a young kickstarter project. Instructions and the user experience were very solid.
Awesome. I love mine. The only issue I have is the USB port by the wireless charger is always on even with the truck off. So if I am on a call and turn off my turn off the truck, the phone reconnects back to the truck until I walk far enough away. I think they need to lower the transmit power more on the aawireless because the signal goes pretty far, even though a previous update lowered signal power already.
I have mine set up so that AA only connects when the Bluetooth is connected to the truck. It is an option in AA. When the truck is off, the stereo is off, Bluetooth is disconnected, and AA disconnects.
In a update awhile back they said this was on the list of things to fix via app/firmware update.
Hopefully soon as it's my only complaint as well.
I don't believe they have it fully working. It doesn't work on mine. I remember them saying they needed to work on this more, but hadn't time with the chip inventory issues etc.
I am not sure what to tell you. I have been using that feature for quite a few months and specifically enabled it to address the problem that you are discussing.
Are you up to date on firmware? We can compare versions if you want.
Slow your roll there buddy. Glad it's working for you it's not for me. I just walked out opened the door and it connected without Bluetooth being connected or the truck started, and from above the feature is enabled. So it's a valid point. They even said it back in June if you'd like to read it... again.
Slow my roll? I offered you help. Have fun with yours not working. Mine works great with the Bluetooth trigger. It is ridiculous for you to say it isn't working when it is quite literally working in my front yard.
I got my AA Wireless on Monday and used it for 2 days now. I can not get use to the difference in screens so I am thinking about selling it. If anyone is interested please message me. Unless I'm missing something that i dont understand. I like just connecting my phone with Bluetooth so I can answer calls and listen to Spotify.
Definitely sounds like you're missing something. You can continue to use the built in Ford interface if you so choose. Personally with Google Maps or Waze + Spotify in Android Auto I don't see the need to use the default Ford Sync. But again, you can continue to use that if you like and still play Spotify through Android Auto and connect wirelessly with the device. I'm not seeing a downside.
Yep the whole purpose is to use the AndroidAuto interface instead of Ford's. Because of this module I use Android Auto 99% of the time. The only time I go to Ford's interface is for heated steering wheel and changing the audio input.
I like using it for Waze the most.
I realize this is focused on trucks with Sync3 but will give you a bit of feedback from my 22MY Sync4 truck that has wireless AA built in. Overall it works fine and there are no issues with the integration but WOW does it drain the battery on my phone quickly. If I put it on the wireless charger I would say the charger slightly offsets it but I cannot expect any drastic charging gains. I have since switched back to a wired connection to charge if I will be in my truck for more than a few minutes.
How are the add on wireless dongles? Same experience or better??
I don't think it's specifically due to running AA Wireless or even Android Auto. I think it's more with the apps that you use which drain phones pretty good on their own. Google Maps + Spotify running is going drain any phone battery pretty decently. I don't even use the wireless charging pad anymore it's absolutely terrible. Around town I just leave it running over AA Wireless dongle and I'm not running navigation apps just Spotify. If I'm taking a longer trip out of town then I usually just plug it in for charging (tried the charging pad and it won't keep up).
I actually am not actively using any apps most of the time since I already know where I am going without a need for nav and tend to just listen to Sirius. I will have to check if Google maps (or Waze, etc) are automatically running in the background when AA starts. My phone battery life typically lasts me all day if I am not driving so there is something going on... maybe it is not specifically AA as you say, but something that starts as a result... thx
Yea that's interesting. My experience with AA Wireless dongle it looks exactly like when plugging it in and it will default to your last used navigation app when started. That might be a setting, but it will always pull up the map for me and then I have Spotify in my launcher also for switching back and forth.
Originally I still had a Pixel 3 and the battery was pretty garbage. I have swapped to a Pixel 6 and the battery is amazing so I just might not be noticing it as much anymore. No experience with the new sync and how they implement the AA Wireless so there could be something there as well.
