You want robust and sturdy. Dont cheap out here cause they will vibrate and be annoying. THe SDHQ brackets are nice for this application.
I need to find pictures of both now. I really want to put my big bangers up there.Our brackets are engineered in-house in our facility in San Marcos, CA and use a premium powder coat for a durable finish. SDHQ is a great friend of ours and they make a great bracket as well. Our bracket lays a little more center and their solution sticks out a little further out. Both can handle an XL or Lp4 no problem so just comes down to personal preference.
Best,
Brahian Herrera | Forum Sales & Support
Email: [email protected] | Phone: (760) 560-2252 Ext 201
I did not know you guys were right in my "backyard". I live in Vista just around the corner.
I "gotta" hand it to you guys for being so professional - always. And so helpful. Your customer service is incredible. I'm thinking the choice between the two mounts probably comes down to whether one prefers sticking out a little more vs. more centered.Our brackets are engineered in-house in our facility in San Marcos, CA and use a premium powder coat for a durable finish. SDHQ is a great friend of ours and they make a great bracket as well. Our bracket lays a little more center and their solution sticks out a little further out. Both can handle an XL or Lp4 no problem so just comes down to personal preference.
Best,
I have the sdhq with baka designs squadrons mounted. The brackets are SOLID and fit really well. The littlest bit fiddly but if you follow the instructions methodically the install goes well.
Currently in the middle of installing the first (driver) mount. Following instructions to a 'T' and my fender is making contact with the bracket when i hit the step to align the edge of the mount with the flat fender edge. I moved it around a bit but with that piece installed that fastens with the 10mm bolt, i cant get it to NOT touch.SDHQ user here. I liked the newer version over the older version from a few install videos. Go slow, be patient. All fits well and is a stout mounting point.
I need someone to make some Stainless Steel tabs to fit a second smaller set of side lights pointed 90* out.
Its called self-clearancing. Thats exactly what mine are going to do.Mine is just the same. Like SUPER close and tight. It might be rubbing but I let it ride.
sdhqoffroad.com
sdhqoffroad.com
FYI for anyone who installs these SDHQ mounts. I broke a few of the cowl clips taking the cowl off.Its called self-clearancing. Thats exactly what mine are going to do.
I did have to take my bandfile to the machined puck to fit drivers side but they are all installed. They look pretty good and seem pretty stout.
Needless to say, i'm glad i didnt have to design these.
I used a Rugged Radios mount for an antenna, and have no issues in the car wash. Across the border from you in Wisconsin.Anyone experience issues in automatic car washes with the A-pillar mounts/lights? I know, wash by hand, but here in MN it is not always feasible. It's been the only thing holding me back from picking up a set.
What’s that stubby antenna for?
One is for truck radio (replaces stock antenna) and other is for GMRS radioWhat’s that stubby antenna for?
