7-way wiring issue
Florida
2024 F350 Lariat Tremor
Curious to know if this sound familiar to anyone or if it’s just a me-thing:
2022 F350 Lariat, Tremor, 6.7 - towed the 5th wheel for the very first time over Labor Day with the new truck and never had this issue before on the last truck so I’m assuming for now that this is a truck issue and not a 5th wheel issue.
with the headlights/parking lights OFF and the 7-way plugged in, no issues at all. However, turn the headlights or parking lights ON (which I need to do in the daytime to power the 5th wheel rear-view camera) and then every time I either touch the brakes or use the right turn signal, shortly thereafter I get a “ Trailer Right Turn Lamps Fault Check Lamps” message. As long as that dialog box appears, any further use of the right turn signal results in the “quick blink” normally indicated when you have a burnt out bulb. But selecting the “ok”, the message goes away and the blinkers all work normally. Also associated with that warning message is the annoying 3-chime sound…😵‍💫😖😫
checked and electric-greased the plug with no luck - needless to say, that gets old after towing 600 miles! open to any feedback or suggestions!
