7.3l Godzilla front crank seal leak
OIL PAN REMOVAL
The service manual says to remove the nuts off the exhaust and trans support, lift the motor 4" and swap the pan gasket
Sure there are a few minor additional steps but this is about it.
Book calls for both motor mount bolts to be scrapped and replace with new.
$5000.00 for labor is pretty high for this job.
I am very disappointed to have to post this but after being under my truck yesterday while installing a 2.5” ready lift leveling kit, I noticed I had a little oil on the pan. Upon further inspection, which didn’t take a whole lot of inspecting, I found it to be coming from the front crank seal. I have 26k on the truck and would not expect this issue to be happening with so few miles but I guess these things can happen. Hopefully my local dealer who I will say has provided me with terrible service thus far can resolve the issue for me. I will keep you all posted.
Great. I'm so excited... Front crank seal is leaking and I'm already beyond anxious about what's involved. Not knowing how they're going to do the job. Marring up the internals. I better look for your follow up post....
Just found a leaky crank deal on my 2023 7.3. 30,000 miles, looks like it's been leaking for a while. Dropping it off at the shop tomorrow.
As another 1 to the list....🤦🏻‍♂️
Wow, I just crossed 30K myself. Thank god for warranty. 😅
Add me to the list.... Just drove 3.5 hours upstate and when I arrived I smelled burning rubber almost like a belt. Checked and there is oil all over the underside starting right at the front of the engine. Checked oil level and is barely registering on the stick. Got my guys getting me a jug of oil to fill her back up and get home. Got Ford service in the line as I type looking to see the earliest appointment available. I'll have to bring up the three other things when I bring it in. Merry Christmas..... 🤦🤷😭😭😭
Mine is a '24 btw, just noticed the (20-22) 🤣
2023- just got the note from the dealer I "might" have this front crank seal issue. I asked them to wipe it down and I'll check for oil under the pan next week. Thank god I have the "premium" extended warranty because I have 64k on the truck.
I just had mine replaced a few weeks back as well. 2021 F350 7.3 Godzilla 31000 miles. They resealed my rear diff cover because it was wet as well.
Just noticed mine a couple of weeks ago. Not bad, but definitely leaking. 35,000 on the truck. Will be making an appt. with the dealer as soon as they get parts for the steering wheel column recall :mad:
Well- confirmed it was the front crank seal. Do these things just go or is there something that causes it to pop, like a bad PCV valve or something? Edited to add- mines a 23. Mods- you can move this to the 23 problems sub if you want.
