7.3 Knocking Noise - Engine
LetEmRun
Tremoraholic
Idaho
2022 F350 Tremor 7.3L
Truck is going in Monday to diagnose a loud cyclical knocking noise coming from what seems to be the engine bay. Attached is a video. Anyone experienced something similiar?
Actually noticed that the noise kicks in when I turn on the defrost mode. Noise immediately stops when I turn off the defrost. I am thinking the compressor is messed up.
I first noticed an odd noise from the compressor on my 2020 the very first winter I had it and used the defrost. I hadn't noticed a noise like it from any other a/c compressor before. That being said mine was not loud or crunchy sounding like yours, and it still works fine and makes it's odd little noise when it's cold out. I think it's good you're having that looked at, hopefully it is something as simple as the compressor.
If it kicks in with the defrost it's probably something with the AC compressor.
72k on my 21' 7.3. Heard noises over the years, but nothing like that.
Look at the A/C compressor as you have someone else turn it off and on. You'll know right away if the noise is coming from there.
Good luck with the fix.
