7.3 godzilla will not start
I have a 2021 F250 7.3 Godzilla King Ranch, 4 WD, 12,500 miles and will not start all the time. Sometimes it starts right up other times it just spins over but will not fire. I can wait an hour and it will start up. Dealer has had it for a week, but these parts changers have no idea how to fix a problem. They did replace the battery, failed to start the next day. Anybody got any ideas? Thanks, Plugster
I had intermittent issues with starting by button or remote and door locks by remote or door button. Other electrical gremlins too. It was caused by a loose ground at the BCM. This occurred at 35,000 miles on my 2020.
I’m having the same. Passenger door lock randomly would not work. Now it’s fine. Now the drivers side mirror fails to fold when locking. But works if I push the button to do it manually. It’s a Strange truck sometimes.
Oof. I had a loose ground on a 350z years back and it was by far the worst experience working on a car in my life. Took so long to trace it down -- the way it surfaced was when it would fry a solenoid in the trans valve body. Eventually traced it down to a ground in the passenger floorboard that by touching you would have thought was good --- but what had happened is they, at the factory, put the ground on paint and over years that paint wore and it was every so slightly loose. Just enough to short and fry a solenoid.
I pulled that valve body probably half a dozen times, maybe more, fixing fried solenoids before I finally figured out the source was that stupid ground. That last time it had fried the TCM and I was so pissed at that point I replaced the whole valve body, TCM, and all the solenoids in one pass. Gave it a couple thousand miles to be confident everything was good -- and sold it with a disclaimer of what had been the issue.
Very unpleasant experience, for sure. Electrical issues suck. I'd rather throw a rod. At least then it's clear when you're effed. Electrical issues are like women -- you have a problem and it'll surface up all over the place except for the source of the actual problem, leaving you wondering wtf is going on.
I know this isn't helpful, but I just keep seeing these quality issues pop up in this forum.
I've seen more quality issues, and serious problems, in this forum with only 3 production years of a truck than I have in the entire time I've been on the Tundras forum, and I joined that forum in 2016 and am still active there..
I can only think of 1 or 2 complaints of a new Tundra owner that were more than a minor "i wish the infotainment system was better" or "Ford has a more refined interior."
Even the Tundra that melted while rescuing people in that California fire still started up and ran when Toyota replaced it for free..
I'm just waiting for the day my truck doesn't start or spontaneously combusts or something. =\
Don’t kid yourself it’s not all roses with Toyota either. My coworker has had his new old generation Pro in about half dozen times for various issues another freind got a Tacoma bought back. They are such diehard Toyota fans won’t talk much about it. They are a decent vehicle but in my experience not near as trouble free as everyone claims. My last Toyota needed a bunch of new seals and water pump at just over 60K miles and 6 years. Maybe myself and friends are getting the Friday builds but they haven’t been any more trouble free than anything else.
Back to the actual subject for the OP are you using a winter blend fuel when traveling to the hotter climate?
Yaup. They all have problems. The only thing that matters to me is how they handle those.
Of all the manufacturers -- Honda is the only one I have had to fight to get to honor their own warranty and that was on an engine that failed under 2k miles. It was a known, widespread, issue. So, with that, Honda is the only brand that is on my blacklist. Had dozens of cars in my life and they are the only brand that as a matter of corporate policy will deny valid warranty claims.
Toyota has FAR less.
None of those are
Transmission broken, been in shop 4 weeks
Brand new truck won't start
Fit and finish damage all over brand new truck
Spark plug wires spontaneously combusting
Transmission fluid leak in BRAND NEW TRUCK
etc
Yeah, I didn't claim Toyota didn't have issues. My claim was that the frequency and severity of the issues reported here in a short period exceed both the rate and severity of issues I saw with any Toyota I've ever owned over a far greater period. I still make that claim.
Don't forget mine needed new heads before it left the dealership :)
Everybody was so gung-ho about the new 2022 tundra coming out. Saying Toyota‘s never have any issues, they design everything great. The 2022 tundra has been a nightmare so far. But it happens to them all. Toyota fan boys are just in denial. If you don’t redesign something in 15 years it should be solid and reliable. I had a few tundras. One was bought back by Toyota before it was labeled a lemon.
Here's an easy check for fuel pump operation when the truck won't start -
remote unlock the truck, open the drivers door, and you should hear the fuel pump, as it should "turn on" and run for a few seconds. Mine pressurizes every time I open the damn door. Stupid programming if you ask me. There's no need to pressurize the system every time the door opens.
This may not be your issue, but at least it can be ruled out, and you can move onto something else.
Did the dealer find any codes at all?
Okay so mine stopped primimg ever time i open the door is that normal? Truck has 4900 miles on it?
Bump in this thread.
My 7.3 has a similar issue as the OP. What mine does is, only when it’s warm it will crank for 5-6 seconds before it fires up. When it does fire up it starts out rough then smoothes out. But it Always Starts! When it’s cold it cranks right up! Can’t figure it out. And unfortunately my truck is now out of warranty so I’m gonna have to foot the bill to fix this issue.
