7.3 godzilla will not start
15 years owning first and second gen Tundras. The fact is Toyota does a far better job engineering and building a quality product. On Tundra forums the posts are mostly about which tire/wheel combo and which exhaust. Big 3 forums are almost comically different and loaded with posts about substantial problems.
I'm leaving Toyota to try a Ford but if the blue oval lets me down i'll go right back to a pre '22 Tundra.
I spent my fair share of time overseas in a 3rd world shithole. You will never change my mind that the Hilux/taco isn't the most dependable truck ever built.
I'd like to have a Taco just as a "spare vehicle"
You’re right. Not helpful.
For a person having this issue, I learned nothing from your post.
It's a fair observation and partially why I'm getting rid of my '22. The fact that mine wasn't assembled properly at the factory and all these issues popping up in a forum that represents a relatively low # of Superduty owners, his statements are relevant.
Top Gear and Whistling Diesel made good examples of Hilix durability. I wish they sold the diesel in the states.
The comment was not relevant to the specific problem folks are reporting in this thread. The poster even started by saying “probably not helpful”.
I’m glad you were able to use this opportunity to advance your gripes but, again, I learned nothing from either of you about the problem at hand.
Congratulations - it's an open forum, get used to replies that don't always address the issue at hand. I can understand if OP has an issue with the responses, but your responses are just about as useless as ours.
Don't you know the only purpose of trucks is to tow around mobile homes every day?
You must not be truck enough.
May as well get a Camry, poser…
Well, the cat is out of the bag. I guess I'll just bumper pull and do my construction/demo work with a 4 door sedan from now on.
Another for the ignore list
You've been blocked by the thread Nazi too, guess not pulling a 5th wheel is too Liberal for this fella.
If anyone else has ideas to fix the OP reported issue, many of us would appreciate your advice as we are actively dealing with it.
For the Toyota fanboys, I guess carry on as you are prone to, due to lack of self control. Very easy to just hit Ignore for me.
So if this was happening only after long periods of time sitting i'd be inclined to think fuel pump with the guess being that the system loses pressure over time. If it happens after a brief shut off period i would think there'd be enough fuel in the lines to get it started easily. BUT i'm not familiar with this new fangled fuel injection stuff.
Have they confirmed spark? That can, iirc, be done with a simple meter placed over the plug wires so you don't have to do the old school pull the wire trick.
Ok just reread OP and i think fuel pump is the wrong direction on this. Gotta be some sort of vapor lock type thing. And i would think that is not something that doesn't throw codes.
Good luck! Keep us posted.
Thank you. Any idea on how to troubleshoot and prove this? I’d like to provide a roadmap for the dealer given their lack of help so far.
A couple of our fleet F150s have done this. Seems random. Generally we reset the fuel pump relay (maybe). It’s a sequence with the key. I have heard some fords have reset button under passenger side kick panel but haven’t confirmed for myself.
It doesn't look like the OP (plugster) is even an active member any longer so we will most likely never get closure on this... I still stand behind my hypothesis in post #19 as a worthy explanation.
The only way you can fix something like this is by being able to reproduce it. If the truck starts sometimes but not others and isn't throwing a code than most likely there's something loose.
Had a similar issue in a 350z and it ended up being a loose ground. Was a real pain to track down.
You can get an ODBII reader pretty cheap from a lot of places. Get one, when it won't start plug it in and see if you get a code. A lot of codes will clear themselves once you start it up.
