I have followed and thoroughly read the 3-4 ongoing threads related to 7.3L vs. 6.7, towing weights, camping/campers, etc. Looking for some experience and insight on purchasing a 22 F350 with 7.3L or 6.7L.
I currently drive a 21 F250 Lariat Tremor Ultimate 7.3L and tow a 38' 5th Wheel RV. Just placed an order for a 22 F350 Tremor, same spec except with a 6.7L. This will be my first personally owned diesel. My 21 F250 can sufficiently pull the RV, but I want a bit more towing safety cushion for all the reasons cited across these related threads. My RV weighs 12700# unloaded, and will not exceed 14K loaded, pin weight is 2800#. My F250 has a small amount of room ref GVWR, Rear GAWR, and payload. I don't expect to ever trip the CDL limit for GCVWR (currently at around 22K loaded). I've looked at all the weight calculations and used several certified scales to weigh. But...even if only a door jam sticker change between F250 and F350, I am upgrading to the F350 for the peace of mind. Expected towing use: 4-5 longer range trips (1000-2500 miles) per year, and several short trips in between (~100-200 miles or less). Other usage would include daily around town and occasional light trailering.
Request for this group: Looking for insight/experience to inform my decision to stick with the ordered 6.7L or switch to a 7.3L. Growing concerned about references here to regular maintenance, major repair cost, and the nominal towing/weight capacity gain of the F350 with a 6.7L.
@soop I reviewed your weight comparison chart as well and that is partially driving me to this question.
