7.3 gas or 6.7 diesel?
Sounds like people who are smart and analytical who dont absolutely need to tow 15K daily all choose 7.3L
Seems the people who buy things to look cool and feel bad ass all bought the 6.7.
(The guys who actually tow heavy and often of course need the 6.7. So that makes complete sense.)
But if youre towing less than 10k and less than 3-4 times a week, you are just throwing money in the wind to say you have a diesel and be able to say whoa 1050 lb ft of torque and grunt like Tim the Toolman.
Rubicon all day ??
Haha. I just totally derailed This thread.
I got rubicon, put Dana 60s under it. ARB lockers, manual disconnects for the sway bar because I was having trouble the electronic disconnect, replaced rock rails and put 37s on it.
but I still have the stickers and rubicon transfer case. Hahahaha
The 7.3 is the best big 3 gas truck engine on the market now so it is converting alot of diesel owners over, making the debate even more heated. Obviously the topic has been gone over many times, just have to read up and make the best decision for YOU and YOUR money.
Diesel is 2 seconds faster in quarter mile. Better fuel mileage. Better towing. Gets more chicks.
Only thing the gas motor has is it's lighter and costs less.
More like 0.1 Tremor to Tremor. https://www.zeroto60times.com/body-style/pickup-truck/. I also remember seeing a 2 second comparison but if memory serves it was Tremor to non Tremor just can’t seem to find the article.
As for max towing in full rated trucks is only 1600lbs difference in F250 1900 lbs F350. Another thing is F350 full rated variations gas will have approximately 500LBS more payload than similarly equipped 6.7L. May be a non issue for OP with stated trailer. In 250 varieties payload is very close to the same sine the standard GVWR is upped on the 6.7L to cover the extra engine weight.
The diesel is going to have a range advantage with the better fuel economy and has larger aftermarket tank options that are not available for gas at this time.
In the Tremor the diesel is only a $8500 adder. Depending on fuel costs in your area the better fuel economy cost savings can be offset by the typically higher diesel prices. If running the penny pinching # depending on how many miles you drive per year and how long you want to keep it could actually be cheaper in the long run to get the diesel with predicted higher resale on the diesel. Lots of calculators out there that address this. With current fuel prices and a assumed 30% depreciation in 5 years I won’t save enough in operating costs to cover the extra price of the diesel. My coworker on the other hand using same calculations comes out to the good after 5 years using his expected annual mileage numbers. That is assuming the diesel at time of resale in 5 years will fetch $6500 more than gas.
If following the manual both engines should be fairly reliable but Deisel has some different driving recommendations for the emissions system to work correctly. They recommend limiting idle time and short trips on the diesel.
Both options will get the job done well and more of a personal preference thing on what you want really want.
P.S. the 7.3L handles 7K trailer with ease even going over the continental divide.
If your towing much, the diesel is the option especially at altitude like Colorado. Gasser struggle at 11,000 ft in the mountains.
Not with a 7K trailer. Didn’t seem to struggle much on the TFL heavy test either.
This. TFL pulled a 16,000 pound trailer up the "Ike" in an F250 7.3. Over 11,000 feet elevation. 7% grade. About 60mph the whole way. The 7.3 has as much power as previous generation diesels. The 7.3 is plenty of motor for this truck. Will the diesel pull it better? Yes. The 6.7 is a turbocharged space age oil burner generating tremendous power with the potential of ridiculous repair bills, while the 7.3 is an old school push rod gasser. The 7.3 is easy to work on, and is derated at 430hp in these trucks. With moderate mods folks have seen over 700hp normally aspirated with this engine. (over 1400hp turbocharged, but that's crazy talk) If you are towing heavy all the time then the diesel is a great option, but then a dually would be better anyway, not an off road truck. It is not a cut and dry decision. I'd say for the tremor's towing capabilities, it comes down to more of "want" than "need" because the 7.3 is a very capable engine. That being said, the 6.7 is awesome. If you drive it, you will want it.
1450 HP
Thing sounds amazing!
If you mention TFL you should also mention the 7.3 barely made 430 HP at the crank while the 6.7 made almost 475 HP to the rear wheels when they dyno’d them.
True. While we are mentioning TFL they also put a $6k procharger in a 7.3 and got 675HP at the wheels, for 2 grand less than the diesel option.
Sounds like someone is regretting their decision
And lost warranty and now have to buy fuel that costs more than diesel.
I'm a guy that pulls a 36 foot travel trailer that weighs about 7,000 lbs. all over the country. Currently do it in a 5.3L Suburban with the tow package and self leveling rear suspension. Yeah it does the job, but when that asshole doesn't know how to merge onto an expressway and I have to hit the brakes, I end up taking 2 miles to get back up to speed. Headwinds turn fuel millage to a whopping 5 mpg and any incline makes it rev to about 4,000 on the tach. As for maintenance, I've had to replace the torque converter, both axles and the suspension. Suspension wasn't under warranty so that was close to 5 grand.
Yeah a 7.3 would be a great improvement but I want an absolute pulling machine that will not even know it's even hooked up to the trailer. Not to mention the extra power when I don't have a trailer on it. That's why I ordered the 6.7, Is it overkill? Probably, but I don't care. Buy the way, does anyone know where I can find those ball sack things I can hang on my hitch?? LOL!
I echo what most others have said. 6.7 vs 7.3 is really a personal decision based upon the various factors that are important to you and your truck; all are relevant to the truck owner and may be totally irrelevant to every other single person on the planet. It doesn't help really answer the question other than to say there is no answer because no one else knows your intentions for your truck. I also weighed the decision extensively. For me, my main factor in choosing diesel was range.
A 50 gallon tank in the bed (tonneau and 5th wheel compatible) and 60 gallon mid ship replacement give me 110 gallons on board. At 12-21 MPG (my estimate of heavy towing to unladen), that's damn near the entire way from Las Vegas to Washington DC (a route I drive round trip 2-3 times a year) with just a single refueling stop, one I intend to make around Missouri for the less expensive fuel I always seem to find there.
By comparison, a 7.3L getting 8-14 MPG with the stock 34 gallons and no real replacement or auxiliary options is at least 6-10 fill ups if not more.
And no, I'm not driving straight through and stop plenty to stretch the legs and what-not, but the option to not have to refuel every 3-4 hours while towing at interstate speeds appeals to me very much.
