An admittedly very expensive funnel (for a funnel) arrived recently and it was worth every penny. Back when I did my first oil change, I realized how hard it was to access the oil fill on the valve cover; Tall truck and engine sitting deep in the engine compartment. Sure there are generic funnels that you can snake down there, but still need to figure out a way to support it and pour slow because the throughput isn't very fast. I'll have none of that.
I'd made do for way too many years of my life and saw the light of the fitted funnels when I got one for my wife's 4runner. Straight neck fitted ones won't work on the 7.3L because of the valve cover angle. This funnel was the answer and since I will have this truck a loooooong time, for the cost of less than one tank of gas, it's mine. Will do my second oil change in the next few hundred miles. And, this will be first oil change using the Fumoto valve I installed during the first oil change.
I got the larger of the two funnel sizes just because. Oil jug for size comparison. I test-fit it and it takes a second to figure out the angles involved to get it to seat and then screw in and then unscrew and remove, as it just barely fits between all the harness/tanks/cables/lines running all over the place, but it's only a few second learning curve.
Thank you
@PilotGore !
Funnel porn:
