3000 WATT INVERTER FOR TREMOR
I just bought the tool box. I worked all day on my deck project, I’m spent, but just didn’t think twice.
Now I need more info and more links to what to buy. I don’t mind getting that 4000 watt inverter and have it so it can be removable.
Keep on giving us your wisdom. I’m sincerely grateful. Thanks Bob. You the MAN.
Don 😉
On the jump starting the truck with the Anderson connector idea; I had this idea as well in my build thread but recently nixed the idea since, Anderson doesn't make above a 350 amp connector in Powerpole series. They make a 550 amp in Multipole series, but not sure if that's enough either. It may work since it isn't a sustained 550 amps.
UPDATE: see my follow up post below. Should work! @Iron Man
@Iron Man Here you go. Up to 550 amps per pole (SBX 350). Yellow is the recommended color to be 'proper'. You would need two housings as well as the contacts.
The advantage of my recommendations is you can hook up other items with demanding high current, should you ever need. (winch, jump start semi-truck, etc)
Housings - backordered (two needed): https://www.mouser.com/ProductDetail/879-6362
Contacts (four needed): https://www.mouser.com/ProductDetail/879-6358-BK
You will need 350 mcm wire. 350 mcm Class K welding cable should be good for 552 amps.
If you are looking for a simple solution to add an external connector for jump starting, take a look here.
Cables and connectors current ratings:
To start a vehicle a battery can put out way more power than these connectors are rated for. However, the battery can only put out that power over a short period of time. The rating provided by Anderson is calculated based on the size of the conductor, the surface area of the contact and the resistance of the material in a continuous situation.
As you flow current through a conductor there is always a resistance and this resistance generates heat. The amount of resistance goes up as the wire gets longer. So, as more current is passed through the conductor the temperature increases. If it increases too much then things get too hot and start to melt. This is how a fuse works. If you continue to flow the current the heat will continue to build. When the current stops, it starts to cool back down.
If you are passing a great deal of current through a wire, you can select the connector and wire based on it's current rating and on it's duty cycle. So for starting a car, where you only run the starter for a few seconds connected to a battery putting out 800 Amps, you don't need to use cable and connectors rated for 800 Amps continuous. In fact, if you look at the factory cables that connect the battery in your truck you can see that FoMoCo has used wire that is 2 AWG which has a continuous current rating of 200 Amps when less than 8' long.
In the link I provided above, you can see that I selected the Anderson 175 Amp connector and 2 AWG wire to setup an external jump start connection.
I'm confused as to why someone wants a 3K inverter in the truck. A 3K inverter in the RV certainly. If it's about jumping someone wouldn't a 3000 amp NOCO Boost Pro be simpler and cheaper?
