2026 F250 Tremor 7.3L Engine Break-in
I picked up my new special order 26 XLT 7.3 from Bessemer, Alabama a couple weeks ago with 8 miles on the OD. Drove to Alma, Arkansas which is about 550 miles or so and had a shop do an oil dump and fill w/o filter. Drove on to Kingman, Arizona and had another shop do another dump and fill w/o filter at about 1650 miles or so. I am following the recommendations of the Motor Oil Geek on YouTube. I'm using QS 5W-30 full syn. What I also did was keep speeds at 65-70 mph for about 20 miles in 10th gear and then down to 9th gear for 20 miles. Actually did this quite consistently all the way to Kingman, AZ. I drove the rest of the way from Kingman to Pahrump, Nevada in 10th gear which is about 175 additional miles. I do another oil dump and fill at about 3200 miles and then go on at the OE recommended 5K and filter from then on. I will stay totally with QS 5W-30 full syn. I also installed a Fumoto drain valve for easy peasey and mess free future DYI oil changes. Do you think I should change the diff gear oil as well or just go with factory recommendation?
change the rear diff gear oil, your truck will thank you. Yukon recommends it at 500 miles
A decent analogy may be something like performing engine valve lapping if you get my drift. "wink"
I certainly do, and that's why I'm simply sticking with the Ford oil until further notice. Get them rangs seated.
Lake Speed, Jr. is no slouch. I do regret missing that first early engine oil drain but "so what, now what?" - nothing I can do about it now except follow my every-5000-mile interval, there.
And to your diff covers' point: Our esteemed fabricator colleague MVI does offer a factory rear axle (the 11.6" Sterling) steel diff cover modified to include a drain plug, a fill plug - and a sight plug, along w/ a quality gasket (LubeLocker? - I can't remember).
I have one of these rear diff covers but haven't yet done the axle lube swap. I plan on it and before 15,000 miles. Already have one quart of the Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant (U.S.) - WSL-M2C192-A I bought when I checked my rear axle's fill level, which was less than almost 1/2" low, so I have some of the product already. Sheet's ain't cheap, neither, and I may need 3 more.
MVI includes everything one needs save for the juice itself and your tools.
img_9149-webp.256224
Our front axles take the Motorcraft SAE 80W-90 Premium Rear Axle Lubricant (U.S.) - WSP-M2C197-A w/ a shot of Motorcraft's Additive Friction Modifier XL-3 (U.S.) EST-M2C118-A (clutch type LS) if doing a swap. I just checked the level and it did not need any. Checked both axles after I got it home first time.
Same with the TC?
IMHO, yep. It’s too easy to do, not to do it. Took me an hour for the rear diff. That’s including looking up the bolt torque specs. This is the front with a couple hundred miles in 4wd and a couple thousand on the truck.
IMHO, yep. It’s too easy to do, not to do it. Took me an hour for the rear diff. That’s including looking up the bolt torque specs. This is the front with a couple hundred miles in 4wd and a couple thousand on the truck. View attachment 260939
Yep, I'm leaning towards doing both diffs and the TC even though it's never been in 4WD as of yet except at delivery where I checked pertinent operations.
I'm doing so under one condition. No replacement diff covers and trust me folks, if there was a TC cover of some type, I'd upgrade that too while in there, just because. LOL!
I do wish there was a slip yoke eliminator kit for these TCs. Maybe then it would have a cool cover too 😉
I would do a very through inspection before you leave the dealer and check every main seal and fluid you can. maybe alternate on back roads to vary speed and rpm more. make a few stops along the way to check everything out again.
