2024 Tire clearance issue
Digger
Texas
First Responder
Ff
2020 f250 tremor
I'm on my 5th tremor ... I'm running 37 11.50 on factory ford 20" same set up i have ran on serval tremors the last two 22 and 23 had zero rub anywhere the 24 however has a lot of rub on passenger front sway bar ,i have centered with Cari track bar ,2" bds spacer Carli radius arm drop brackets to correct caster still rubs ? I've ran this set up on 5 tremors all diesel and have had some Control/radias arm rub on the pre 23 but never sway bar rub these are 11.50 not 12.50
The reason this rubs for you is most certainly because of the suspension changes you made. Without getting under your truck i cant say why exactly, but for comparison, i and many others here run 12.50 wide 37s on stock tremor suspension and clear the sway bar with that combo.
I suspect that centering you did with carli track bar moved your wheel further in passenger side causing a rub. See how much clearance your driver side has and perhaps adjust again until both wheels clear.
A funny fact that many of our trucks don’t leave the factory with the front axle perfectly centered to frame. The skinny duratracs on oem 8” wheels sitting within the fender hide that. But if you are to simply swap to 9” rim with 12.5 or 13.5 tires you would immediately notice that the axle is not perfectly centered to the frame. It doesn’t need to be; and thus , adjusting that track bar of yours might help clear with the sway bar rubbing.
Yep, I had this corrected when I took my truck to Texas Motorworx to fix a few install issues on my Carli that a previous shop did.
funny, but i too learned much about SD suspension theory and geometry issues from a botched carli install on my 22 that required a lot of work unraveling and correcting.
It rubbed with zero changes ..... rubbed less after centering
i have ran that combo as well with no issue ... the rub was worse before the changes
Take it to the shop for inspection and advise to remedy the geometry situation. I said it many a times before, these suspension issues rarely get solved on the forum where OPs are providing limited information and there is no chance to inspect the problem.
Each situation is unique, and in your case the mix of aftermarket components (carli, bds, etc) create variables that are not common between standard builds.
Ok what limited information can i add? Has been to shop that does 100s of Carli and bds ect ... was an issue from stock has improved with changes ? So seems as if it's a ford variable not aftermarket
I can’t say exactly why your 11.50s are rubbing where as many with 12.50 on stock suspension are not.
One quick and sure way to remedy this since you are invested into Carli already is to get their torsion sway bar which is designed with much more clearance in mind then oem one.
Here’s my post with 6 ways to remedy the sway bar rubbing issues.
Post in thread 'SUCCESS!!!! 37’s on factory rims, no lift, no rub….'
https://www.fordtremor.com/threads/success-37s-on-factory-rims-no-lift-no-rub.16402/post-424481
I feel that you're 100% correct on this. I noticed it on my 21 Tremor when I put 37x12.5 tires on Method wheels with a +18 offset on it. I wasn't getting any rubbing at all but it did appear just visually that one wheel was out just slightly more than the other. Fast forwarding to 24 Tremor, I have the same wheels but went with 13.5" Nittos and 5" BDS radius arm lift kit and I'm rubbing but on only the driver's side radius arm. So, I did some measuring and went old school and snapped line on both sides and if my measurements are correct my passenger side tire is out 3/8" further than the driver side and maybe causing the rubbing on just that radius arm. I'm going to order an adjustable track today for and hopefully get every centered.
